5 Replies Latest reply on Dec 3, 2008 1:59 PM by levancho
    Map Java Object  to AS3 Object
    amol bhandwale
      Hi All,
      i have a following java value object class :
      eg :
      private long clientId;
      private boolean clientIdUpdated;
      public long getClientOrgId() {
      return clientOrgId;
      public void setClientOrgId(long clientOrgId) {
      setClientOrgIdUpdated(true);
      this.clientOrgId = clientOrgId;
      public boolean isClientOrgIdUpdated() {
      return clientOrgIdUpdated;
      public void setClientOrgIdUpdated(boolean clientOrgIdUpdated) {
      this.clientOrgIdUpdated = clientOrgIdUpdated;
      i need to convert into AS3 object class.
      Thanks.
        • 1. Re: Map Java Object  to AS3 Object
          Michael Borbor Level 4
          You should check this link http://livedocs.adobe.com/flex/3/html/help.html?content=data_access_4.html in the Flex Docs the section Converting data from Java to ActionScript
          • 2. Re: Map Java Object  to AS3 Object
            amol bhandwale Level 1
            thanks for reply,
            i hve created the AS3 class as follow,
            import com.adobe.cairngorm.vo.IValueObject;
            [RemoteClass(alias="com.PersonVO")]
            public class PersonVO implements IValueObject
            private var _clientOrgId:Number;
            private var _clientOrgIdUpdated:Boolean;
            public function get clientOrgId():Number
            return this._clientOrgId;
            public function set clientOrgId(_clientOrgId:Number):void
            billToAddrLine1Updated = true;
            this._clientOrgId= _clientOrgId;
            public function get clientOrgIdUpdated():Boolean
            return this._clientOrgIdUpdated;
            public function set clientOrgIdUpdated(_clientOrgIdUpdated:Boolean):void
            this._clientOrgIdUpdated = _clientOrgIdUpdated;
            it contains other fields also.
            when i create a object of PersonVO and set some fields at java side i am not getting exact value for each flag corresponding to fields.
            eg: for string data type for some i am getting true value even though i hve not set it at client side.
            Thanks.
            • 3. Re: Map Java Object  to AS3 Object
              thanks for reply,
              clientOrgIdUpdated = true;
              Thanks.
              • 4. Re: Map Java Object  to AS3 Object
                Karl_Sigiscar_1971 Level 3
                You might also want to add the [Bindable] metadata tag if you use Remote Object or [Managed] if you use the Data Management Service.
                [Bindable]
                • 5. Re: Map Java Object  to AS3 Object
                  levancho Level 3
                  this link : http://livedocs.adobe.com/blazeds/1/blazeds_devguide/help.html?content=serialize_data_2.ht ml#312520
                  explains everything in very good details,
                  hope that helps
                  kind regards
                  Levan
