0 Replies Latest reply on Feb 14, 2009 6:39 PM by (Craig_IAFF)
    help with keyframes
    Level 1
      When adding any effect to a clip, only the first keyframe works. Any subsequent keyframe has no effect. This problem only happens with a clip that I have changed speed with time remapping. After some more trial and error I have found that the keyframe is animating with the clips original 100% speed. If I drag the clips out point further along the keyframe starts to animate but much later than it is suppose to. In the effects control panel I can see the timeline curser pass the keyframe and then much later finally see the effect start.
      This project is SD format widescreen 720x480.
      Has anyone else had any issues with this or am I the only lucky one. Any ideas would be appreciated.
