0 Replies Latest reply on Feb 16, 2009 9:26 PM by (Doug_Swalen)
    Flash Import into Premiere Pro CS4...
    Level 1
      I've run into a problem importing streaming video files into CS4. These are Flash files. They play correctly in Adobe's Media Player. But when they are imported into CS4 the audio synch goes haywire and the audio ends well before the video is done. You can even see the waveform stops well before the clip is over. It's not like the audio sounds like someone was sucking on helium balloons either. It's just not in synch anymore.
      Is this a known problem? If so, is there a workaround?
