This content has been marked as final.
Show 7 replies
1. Re: Some Media Encoder Workarounds
JSS1138 Feb 23, 2009 11:47 AM (in response to jefbak)CS4 works differently than previous version. One key difference is that the sequence is written to a new file just before export so that you can continue to work on that same sequence while it's being exported. I suppose you'd need to make sure that the sequence can be written and read from. -
2. Re: Some Media Encoder Workarounds
jefbak Feb 24, 2009 1:08 PM (in response to jefbak)One issue might be that this project uses mjeg hd footage from a Nikon D90 camera. I might be having some codec issues with media encoder in Premiere Pro CS4. But when I import the project into AE I can render the project to Quicktime Animation codec (which is what I was trying to do in Premiere.) -
3. Re: Some Media Encoder Workarounds
JSS1138 Feb 24, 2009 1:57 PM (in response to jefbak)Well, there's two things I can see as problematic. Using a still camera to shoot video, as you suspected, and exporting to Quicktime Animation, which I believe is currently broken through Premiere.
If it works via AE, go with that. -
4. Re: Some Media Encoder Workarounds
Bob Ramage Feb 25, 2009 8:52 PM (in response to jefbak)Null pict errors? Any chance you've got Magic Bullet Suite installed? I had to remove Colorista because it was causing a null pict error with the media encoder and locking it up. Once I got rid of Colorista the problem went away and the AME worked fine. The other MB apps didn't cause any problems. -
5. Re: Some Media Encoder Workarounds
jefbak Feb 26, 2009 6:51 PM (in response to jefbak)Hi,
Yes I did remove Colorista but I still have problems exporting. Another 1080i HDV project will not export thru AME to quicktime animation. I also tried .h264 but no luck. The AME que never stops estimating how long the project will take -- just spins away, no error, just nothing.
I also have magic bullet looks in the project, but that has to stay, I can't finish this project without it.
Also no luck importing in AE this time. The titles where not rendered.
I used dynamic link inside the premiere pro project to go to Encore and I was able to transcode and make a working DVD.
But I really need HD output! From Premiere! -
6. Re: Some Media Encoder Workarounds
Bob Ramage Feb 26, 2009 8:59 PM (in response to jefbak)Hopefully I'm not telling you how to suck eggs here, but I think you should really verify that you actually have removed Colorista. If you installed it for AE (or any other CS4 app) it is placed in a common folder and will continue to screw up the AME. It would be in:
/library/application support/adobe/common/plug-ins/CS4/mediacore/
If it's there you should delete the Colorista folder. Failing that I'd start deleting other 3rd party plugins one at a time and check each time if it is the source of your null pict error. -
7. Re: Some Media Encoder Workarounds
jefbak Feb 27, 2009 8:17 AM (in response to jefbak)Thanks. Yes I double checked the directory. I ended up copying the entire sequence into a new PP CS4 1080i HDV project and now I have no audio. Time for another reboot. Also PP CS3 will no longer start!
