4 Replies Latest reply on Mar 3, 2009 1:35 PM by (John_Ing)
    Custom Pixel Aspect Ratios
      I am trying to create a custom pixel aspect ratio using the Interpretation Rules.txt file. Whenever I try this and save me new custom PAR it never shows up when I try to convert my footage to that PAR. This is what it looks like:
      # only adds a custom pixel aspect ratio to the UI
      # uncomment the next line to try it out
      *, *, *, *, * = 1364/1000/"HDV to DV AR", *, *, *
      Am I doing something wrong, I am confused why I don't get an option from the drop down box inside the interpret footage window that reads, "HDV to DV AR" (1.364)
        • 1. Re: Custom Pixel Aspect Ratios
          Jim_Simon Level 8
          I can't help with the problem, but I am curious why you're attempting it.
          • 2. Re: Custom Pixel Aspect Ratios
            Level 1
            It is the best method of getting my HDV video to appear the same size as my DV video in a widescreen DV timeline. I can do thinks like zooming in or changing the timeline aspect ratio to 1.333 but even then I have to change the PAR on both video for it to match and it changes the HDV a good amount. If i could just get this method to work it would be so easy. I don't understand why it is so hard to just make a custom pixel aspect ratio. It should be an easy thing to do.
            • 3. Re: Custom Pixel Aspect Ratios
              Changing to an unusual PAR will probably give you an error when trying to export.
              When you have finished editing your footage you can nest your timeline in a new timeline and scale it up to 103% after setting scale to framesize. Or scale it down t0 55% with no scale to framesize on.
              You can also edit in hdv mode and crop off 14 pixel of top and bottom in the export settings when delivering to dvd-mpeg.
              • 4. Re: Custom Pixel Aspect Ratios
                Level 1
                Regardless of why I am doing it, the function does not work. This should be brought to the attention of Adobe. It should create a new aspect ratio and it does not. It says it will generate a new one in the UI but it does not appear. Maybe I am doing it wrong, or maybe Adobes software is just lying to me.
