1 Reply Latest reply on Mar 7, 2009 5:55 PM by fuaho
    eyedrpper not working
    hhansard Level 1
      Trying to use color match.
      Followed help instructions explicitly.
      Can select eyedropper, but after moving curser out of effect control, the eyedropper disappears and I can not select from either program or source.
      It also appears that I can not use the eyedropper in any of the other effects.
      Is this a known problem?
        • 1. Re: eyedrpper not working
          fuaho Level 1
          I don't know what effect you are using, but for a color key, you simply click once on the eyedropper, (don't try to hold the mouse button down)which selects it and allows it to be positioned in the program monitor for your color selection. You must then adjust the color tolerance to something other than 0.0 for anything to happen.
