1 Reply Latest reply on Aug 16, 2008 11:23 PM by kglad
    Can someone help
      Can someone help me with this piece of code. I am stuck. I have dynamically created some mc's with reference to an array. I want the mc to go to frame 2 depending on the value of the array 0 or 1. I seem to not be able to get the target path
        • 1. Re: Can someone help
          _root.graphShell.periodshell[1001+q] are the movieclips you create in perioddisplay() and _root.graphShell.periodshell[1001+q].gotoAndPlay(2) would direct that movieclip to frame 2, but using a number in the initial position of an object/variable in flash is a bad idea.
          you should change your naming scheme so those names don't start with a number.
