1 Reply Latest reply on Mar 13, 2009 2:42 PM by Bill Seper
    Lost all system audio after upgrading Media Encoder CS4 to 4.0.2.002
      Now the only time I hear any audio is when I play a video timeline in Premiere Pro CS4 (4.0.1).
      Another symptom I now have is that iTunes won't even start playback of any songs. If I click on the play button the seek bar won't start moving at all. As if the system detects no sound card at all.
      In OS X's System Profiler I do see Audio (Built In) in the Hardware section.
      Intel High Definition Audio:
      Device ID: 0x10EC0885
      Audio ID: 16
      Available Devices:
      Headphone:
      Connection: Combo
      Line In:
      Connection: Combo
      Speaker:
      Connection: Internal
      Microphone:
      S/P-DIF Out:
      Connection: Combo
      S/P-DIF In:
      Connection: Combo
      iMac 24"
      OS X 10.5.6
      2.16 GHz Intel Core 2 Duo
      3GB 667 Mhz DDR2 SDRAM
      NVIDIA GeForce 7600 GT
      Audio (Built In): Intel High Definition Audio
      Media Encoder (4.0.2.002)
        • 1. Re: Lost all system audio after upgrading Media Encoder CS4 to 4.0.2.002
          Bill Seper Level 1
          Joel,
          The majority of the posts I see in this forum seem to be coming from guys with Windows systems. (Of course I may be blind). If you were on a Windows machine I could probably tell some things to try, but like a lot of people here, I don't have a clue about iMac stuff. You might want to try posting this question in a forum specifically for iMac problems.
          However, you also might want to look at the sound card's mixer. I would assume that if it doesn't have a software mixer of its own then iMac probably has one similar to the Windows mixer. Anyhow, I would check the mixer to make sure all the proper outputs (especially wave and midi) are still checked and the faders full up. Also, look to see if the soundcard has any virtual outs on it, and see if everything's not getting routed to the wrong outputs. For instance, my MIA card's mixer gives me 8 virtual outs. If the main outputs I use going out of my soundcard into my playback hardware are outputs 1&2 but my card has those outputs muted and has routed most of the sounds to outputs 3&4 and their fader is turned down (or muted also) then I wouldn't hear anything on playback. Maybe installing CS4 messed up the settings.
          Also, look at the file "associations" in iTunes and make sure it's still set to play the same file types (wave, midi, mp3 etc) that it had before.
          Does iMac have something similar to Windows "Device Manager"? You might try looking at that and checking the properties of the soundcard to see if anything looks like it needs to be changed.
          Good Luck
