This content has been marked as final.
Show 2 replies
1. Re: Slideshow Subtitles
Alan Craven Mar 14, 2009 8:59 AM (in response to Alan Craven)It is easy enough to create subtitles in the project, but how do you get them to display in the finished DVD?
If you preview the project, the subtitle on/off toggle is always set to off. You can turn it on and the preview works fine; but if you close the preview, then open it again, once again the subtitles are toggled off.
If you build a project image or folder, the slideshows play, but there are no subtitles.
In Encore CS2 there was a setting to select subtitle language that had to be made to get them to display, but I cannot find it in CS4. -
2. Re: Slideshow Subtitles
Alan Craven Mar 14, 2009 9:37 AM (in response to Alan Craven)Success!
The setting is there, but not as I remembered it from Encore CS2.
You need the Disc Properties panel to be displayed (at the top R of the monitor display). Change the "Set subtitles" entry from "No change" to "1"
