This content has been marked as final.
Show 3 replies
1. Re: Split View Not Working
mike velte Mar 15, 2009 2:43 AM (in response to mikeklar)In addition to vertical and horizontal options for the split screen there is an often overlooked check box; "Show Split Video" -
2. Re: Split View Not Working
mikeklar Mar 15, 2009 6:39 PM (in response to mikeklar)Thank you Mike for responding.
Yes, I did check that box and there really isn't any problem, except me :-(
The tint applied was in a dark frame and I couldn't see that it actually worked... Also, this is the first time I used that option.
Cheers,
Michael -
3. Re: Split View Not Working
JohnMcK Nov 20, 2013 5:12 PM (in response to mikeklar)Mike, it isn't a second copy of the whole output screen you get . . . The single screen splits in the middle of the image. That means you won't see the difference till you make a change to the effect's settings. That will make the top half (or left half) of the single image different from the bottom. Try changing the output from video to luma and you will see the difference right away.
Hope that helps somebody . . . I had a few screams at the screen before I worked it out for myself
JohnMcK
