17 Replies Latest reply on Mar 28, 2009 1:04 AM by stewart@itsIT.com.au
    Premiere Pro CS4
    stewart@itsIT.com.au Level 1
      I have just started using PPCS4 and I have set up a new project. At the start of the project I was prompted to select the settings for the movie file and I selected PAL HD 1080 widescreen as I'd like to shpw the DVD I am making og a widescreen TV and also on a normal size TV.
      The problem I know have is that when I add images to the timeline they are "zoomed" in on and do not display in the original resolution.
      Two qestions; is it possible to change the settings of the project without starting again so that all of the data that is added to the time line is added in the correct resolution and two; is it possible to have a project which when finished can be played on widescreen and also normal size TV. If so what is the best way to go about it?
      Many Thanks.
      Stewie.
