3 Replies Latest reply on Oct 30, 2006 5:59 AM by duckets
    remove quotation marks
    otterman Level 1
      Arrrragh!
      Ive done this before n cant remember how.
      When retreiving a line from a text doc it returns- "lineone'
      I wanna use this as a command, ie - lineone
      I put my question to you, how does one remove the " "
        • 1. Re: remove quotation marks
          Level 7
          str = QUOTE & "line 1" & QUOTE
          if str.char [str.length] = QUOTE then
          put empty into str.char [str.length]
          end if
          if str.char [1] = QUOTE then
          put empty into str.char [1]
          end if
          I added the conditional statements to insure the quotes are there and the
          code won't get rid of necessary characters
          Craig Wollman
          Word of Mouth Productions
          phone 212 928 9581
          fax 212 928 9582
          159-00 Riverside Drive West #5H-70
          NY, NY 10032
          www.wordofmouthpros.com
          "otterman" <webforumsuser@macromedia.com> wrote in message
          news:eht1h7$ss8$1@forums.macromedia.com...
          > Arrrragh!
          • 2. Re: remove quotation marks
            otterman Level 1
            OK here it is,- value
            example - sprite(5).member.model[1].shaderList[1] = value (member("import list").line[1])
            • 3. remove quotation marks
              duckets Level 1
              For future reference, here's a handler which you can use to substitute/remove any characters from any string. (put it in a moviescript).
              http://www.robotduck.com/content/articles/director/tools/string/sub.txt
              For your purpose, you would use it like this:
              newString = sub( originalString, QUOTE, "" )
              Which will replace all quotes with nothing (because of the empty string in the 3rd parameter).
              However - when setting an item in a model's shaderlist, you will need to set it to a value which is a reference to an actual shader in the scene (not just the name of a shader). So perhaps to make your code work, you might need something like this: (I have broken it apart into separate lines and variables, for clarity)
              scene = sprite(5).member
              myModel = scene.model[1]
              shaderName = member("import list").line[1]
              shaderName = sub(shaderName, QUOTE, "")
              shaderRef = scene.shader(shaderName)
              myModel.shaderList[1] = shaderRef
              hope this helps!
              - Ben
