1 Reply Latest reply on Jan 21, 2009 9:07 PM by (Keith_B_Johnson)
    Trouble Using USB Headset to record on a track in Pr Pro CS4
    BLecure Level 1
      I just purchased a Logitech ClearChat Wireless Headset and am wishing to use it to record a voiceover on an audio track in the Audio Mixer. CS4 and Mac OS recognizes the headset but the Audio Mixer will not allow me to
      enable a track for recording. I receive the error message......
      Error message: "The previously selected ASIO driver could not be loaded, and may be in use by another application. The default ASIO driver is now in use."
      No other applications are running.........
      Does Pr Pro CS4 not like these USB devices?
      Bruce
        • 1. Re: Trouble Using USB Headset to record on a track in Pr Pro CS4
          Bruce--
          I had similar trouble. It comes from trying to record from a mono device (your headset) into a stereo track (which is probably what you have, since that is what comes up by default).
          Create a mono track. Set your system setting as you did to see your input from the mic.
          In Preferences/Audio Hardware, select the system default device.
          Now when you enable the track, and press the record button, you should be able to see your levels when you speak.
          Keith
