3 Replies Latest reply on Jan 4, 2009 11:11 PM by joshtownsend
    CS4 Time Warp Issue
    Level 1
      Whenever adding the Time Warp filter to a clip it turns it black. The only work around I can find is to nest the clip which is extra steps.
      Everybody please file a bug report to fix this problem.
      http://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
      Thanks!
        • 1. Re: CS4 Time Warp Issue
          done
          • 2. Re: CS4 Time Warp Issue
            Nesting didn't work for me. I found a known issue at:
            http://premierepro.wikia.com/wiki/Known_Issues#Timewarp_effect_and_video_turns_black
            Apparently others have encountered this problem. This description says changing the clip causes the black video. That has not been the case for me. All I need to do is apply the effect. Disabling the effect restores the video.
            I reported this using the link tlc51369 provided (thanks).
            • 3. Re: CS4 Time Warp Issue
              joshtownsend Level 2
              I don't use Premiere transitions (AE is tool of choice) but it's really sad that this is also screwed up and Adobe has to spend time fixing this instead of working on the more major performance issues. At this rate when cs5 comes out in a year it's gonna even worse than cs4 was out of the box.
              Diminishing returns. By the time Adobe gets the previous versions bugs ironed out they only have 6 months to work on the new version, then it'll be the same errors again most likely because they spent all there time on features like speech to text that only used by maybe 1% of editors.
              I'd be more inclined to by a new version if it had no new features and worked fine out the box......for once.
