4 Replies Latest reply on Jan 4, 2009 11:57 PM by joshtownsend
    Import question
      I am a newbie. Got a stupid question.
      I try to import my HD footage into Promiere Pro CS4. It is MP4 H264 format using my Sanyo Xacti HD1000. For whatever reason, it replayed in the source window like slow motion. I set up the project using HDV 720p30 which uses following setting
      General
      Editing mode: HDV 720p
      Timebase: 29.97fps
      Video Settings
      Frame size: 1280h 720v (1.0000)
      Frame rate: 29.97 frames/second
      Pixel Aspect Ratio: Square Pixels (1.0)
      Fields: No Fields (Progressive Scan)
      I am pretty sure I shoot my footage using 29.97fps as well. What did I do wrong?
        • 1. Re: Import question
          joshtownsend Level 2
          " 1280 x 720 progressive HD video scanning Thanks to highly efficient MPEG-4 technology, the HD1 is able to create high-definition videos at 1280 x 720 pixels at 30 frames per second with far higher quality when compared to conventional video cameras. These are richly detailed images that will display beautifully on any big screen TV. Choose from six different video resolution modes (and six different resolution levels for your still photos!), depending on how your images will be used.
          Advanced MPEG-4 technology The HD1 features SANYO's proprietary high-definition engine to execute a vast number of calculations in a short period of time. This high-definition engine enables the Xacti HD1's advanced image processing functions such as real-time MPEG-4 compression, noise reduction and high-definition processing. Recording in the global multimedia standard MPEG-4 delivers exceptional video clarity and detail in an unbelievably portable configuration. What's more, because MPEG-4 is exceptionally efficient in the way it records digital information, higher quality videos and stills can be saved in smaller files. "
          Could be the camera using some odd way to compress the files. Best bet is to use whatever software it came with. Premiere can't keep up with all these consumer camera. Hell it's having trouble dealing with footage shot from prosumer 3 grand+ cameras.
          • 2. Re: Import question
            Oh....your using an HDV preset (which is Mpeg not h264). You might have to make a custom preset, that's most likely the only way you can get it to work....and it still might not.
            • 3. Re: Import question
              Level 1
              Could you shed some light to me what custom setting may work? There is no H264 for me to choose as source input. I almost tried all reasonable combinations already.
              • 4. Re: Import question
                New Sequence - Choose the 'Editing mode' to desktop then set the rest to match. The at the bottom change 'preview files' to use avi.
