3 Replies Latest reply on Jan 8, 2009 8:25 AM by (Giorgio_Davoli)
    Mercalli has troubles in PP4
    Level 1
      Another problem after no mpeg audio in timeline during clips import:
      When two clip are bit overlapped (example 1 second) in timeline (just to add a transition), you're in trouble with mercalli sw to fix shaking problems.
      You had to:
      1) apply mercalli before overlapping the clips
      2) overlap
      3) re-apply mercalli effect (a warning is displayed)
      4) then you can apply transitions also
      If you try to apply mercalli effect after overlap, no chance!!!
      Any tip to fix it?
      Giorgio
