2 Replies Latest reply on Jan 9, 2009 8:48 AM by (Adrian_Guzman)
    Blending Modes (Compound Arithmetic Effect) not working on CS4
    Level 1
      In CS3 I frequently used blending effects using the Compound Artithmentic Effect in Premiere Pro. I would put a clip on track 1 and the identical clip on track 2 above it. Then add a "screen" bend from within the Compound Artithmetic effect to track 2, then lowered it's opacity a bit. This made a soft heavenly look. The problem is this effect doesn't work in CS4 PP. Either by starting a new project within CS4 or importing a CS3 project that already had the effects. The only thing that happens is the clip gets brighter or darker depending on the bending method I use. Can anybody help?
