1 Reply Latest reply on Jan 20, 2009 9:09 AM by Eddie Lotter
    I work with Premiere Pro on a mac and export quicktime movies to be played on pc's or mac's
      I work with Premiere Pro on a mac and export quicktime movies to be played on pc's or mac's. When I export a qt from Premiere with audio it will not play on a pc only a mac. After extensive research I have narrowed down the problem to this: if you use the inspector in quicktime it looks like this
      DV, 720 x 480 (640 x 480), Millions
      16-bit Integer (Little Endian), Stereo (L R), 48.000 kHz
      I have to run it thru AE to make it look like this....then it plays
      16-bit Integer (Big Endian), Stereo, 48.000 kHz
      SOOOO the problem is the Little/Big Endian. I googled that and it looks like a file/bit structure....anyone know how/why to change it in Premiere? Because everytime I make a movie in Prem I have to drag the sequence into AE and render it there so the sounds works.....
      thanks
