1 Reply Latest reply on Jan 22, 2009 9:26 PM by fuaho
    When will Premiere support TC(timecode) for AVCHD?
    Kim HUC
      Premiere Pro CS4 is not supporting TC(timecode) for the AVCHD format. Mean that all clip is starting at 00:00:00:00 and not the recordet TC!
      When will Premiere support TC for the AVCHD format?
      MVH
      Kim Moltved
        • 1. Re: When will Premiere support TC(timecode) for AVCHD?
          fuaho Level 1
          It Also does not support BWF format *.wav files or timestamp data recorded with MJPEG *.avi files!
          Please submit a feature request because this is a huge time waster. I asked tech support for this in October '08
          The only thing I can suggest is that, if you can export the data or otherwise access it, you can manually attach it to each clip using File\Timecode. Be sure to use different tape numbers for different days/cameras.
          HTH,
