21 Replies Latest reply on Sep 11, 2009 3:22 PM by digabyte
    Merge Audio & Video Clips.
    Adamlonsdale
      Okay i have 2 clips.
      One is the Camera video + Audio
      the other is the Audio from a boom microphone.
      I have them both in a bin, but because they started at different times they are out of sync. I can place the video clip into the sequence, and then replace the audio of that with the audio from the boom mic. But then i want to edit them, and cut them up. Is there any way to 'merge' the boom mics audio with the video clip, all fully synced and place it back into a bin as a 3rd clip?
      Adam.
        • 1. Re: Merge Audio & Video Clips.
          shooternz Level 6
          Line up audio and video (synch it) and then export the clip.
          • 2. Re: Merge Audio & Video Clips.
            Adamlonsdale Level 1
            Thanks, is that the only way though? I mean that was an option, but it could take a while doing that to loads of different scenes.
            Adam.
            • 3. Re: Merge Audio & Video Clips.
              shooternz Level 6
              Well ...yes it is the only way to make a separate (standalone clip)
              Why do you need to make separate clips anyway when you can just synch up the clip, link audio video and edit it?
              • 4. Re: Merge Audio & Video Clips.
                Just to chop it up really, as in set different in out points and split it, so i can speed up different parts and create different subclips (:
                • 5. Re: Merge Audio & Video Clips.
                  shooternz Level 6
                  Why are there different start times on the boom mic?
                  • 6. Re: Merge Audio & Video Clips.
                    I meant because the boom mic is recording to an external device, and not the camera. So im taking video from the camera, audio from a hard drive, splicing them together, and then editing it as thought it was a clip straight from the camera.
                    • 7. Re: Merge Audio & Video Clips.
                      Jim_Simon Level 8
                      Make a sequence called Cutting Board. Place the clip and audio track into that, and sync them up. As you go through, make your cuts across all tracks. Copy/Paste the segments you want form the Cutting Board into the sequence they'll actually be used in. When the first clip is done, remove all the excess and start again with the next scene.
                      • 8. Re: Merge Audio & Video Clips.
                        digabyte Level 1
                        "Why do you need to make separate clips anyway when you can just synch up the clip, link audio video and edit it? "
                        What a silly question!
                        If you've got THOUSANDS of video clips, and then audio recorded on an external source (not the camera), you need to be able to link up the clips so you can select from linked audio and video in the Program Media Browser.
                        If the only way to do that is to lay EVERY SINGLE clip into the timeline, then sync the audio, then ONLY be able to access the linked clips from the timeline... then there is a MAJOR problem with Premiere.
                        I assume the above scenario is not the only way to sync audio and video, but it's the main problem I'm experiencing right now trying to sync RED (.r3d) files to audio so that I can edit our feature film.
                        I need to have the audio and video files synced together (linked) so that I can select from files in my project bins and drag them inton my sequence timelines.
                        Please tell me this is possible.
                        • 9. Re: Merge Audio & Video Clips.
                          the_wine_snob Level 9
                          For the establishment of sync, take a look at this ARTICLE. You can use the boom as your main Audio, sync it up, and then delete/Mute any AV Audio, that you do not need.
                          • 10. Re: Merge Audio & Video Clips.
                            Also, once you do establish sync, if you do not need any of the AV Audio, just eliminate all of it, and then Link your boom mic material to the AV and you can cut like it was the original Audio.
                            • 11. Re: Merge Audio & Video Clips.
                              Maybe I am missing something here, but would not plugging the boom into the XLR on the camera and disconnecting any other mic have been the better approach?
                              Back in the cine days, we recorded all Audio with a separate Nagra, that was synced to the cameras, and then transfered to 16mm or 35mm tape, that was locked in sync, and cut with the film. Slates were not yet digital, but worked perfectly.
                              I will assume that with a "feature film," you slated every take, right? You'll have no issues with the syning, as you have the slate to cue you.
                              If I have missed something very important, then pardon my interruption,
                              • 12. Re: Merge Audio & Video Clips.
                                Jim_Simon Level 8
                                Only in the timeline, not in bins.
                                • 13. Re: Merge Audio & Video Clips.
                                  Powered by Design Level 4
                                  All you have to do is create a new sequence with the video+audio
                                  turn off the camera audio and then sync up the boom audio
                                  once you do that you can then create a new sequence and pull in the first sequence as a nested sequence and cut that up anyway you want and with keeping the audio linked.
                                  You would only have to link it once for each video.
                                  I hope this is what your looking for.
                                  Enjoy:  Glenn
                                  • 14. Re: Merge Audio & Video Clips.
                                    digabyte Level 1
                                    I assume the first sentence was for the creator of the thread, but I'll address it in regard to our project.  We didn't use this method for several reasons, the biggest being that we were running several audio sources (wireless lavs on the actors and two booms in the room) and ran them to a multitrack recorder.  I would also site wanting to minimize cables running to the camera (more mobility, less cable wrangling) as another major reason to not use the camera for the audio capture.
                                    In regard to the slate, of course we slated every take (digital slate).
                                    The issue isn't that we don't have something to "visually" cue us.  The issue (and it's a major one), is that Premiere doesn't allow you to sync video with audio using time code (which both Final Cut and AVID do)... In Premiere you have to do it manually by eye (syncing wav forms to video).  On top of that, the only way to save linked audio and video is in a timeline or nested clips (ridiculously ineffiecient when syncing thousands of files).
                                    You have to either export each linked clip as a new clip with audio and video, or create a nested clip with audio and video.
                                    You SHOULD (as all other professional video programs do) be able to sync audio and video using the time code, and then have the program "remember" where they are synced (the video would simply have the audio locked to it at that point).
                                    Having to lay out every clip in a tineline and either access it from said timeline (rather than a bin file) or create new nested clips for each and every clip (thus cluttering your bins and workspace) is incredibly ineffecient and time consuming.
                                    Again, Adobe REALLY needs to address this issue.
                                    • 15. Re: Merge Audio & Video Clips.
                                      Jim_Simon Level 8
                                      Can't argue with that.
                                      https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
                                      • 16. Re: Merge Audio & Video Clips.
                                        digabyte Level 1
                                        My "request" has been submitted.
                                        • 17. Re: Merge Audio & Video Clips.
                                          I third that.
                                          That would be a good option.
                                          I guess I have never worked on a large enough project where I had as much data as your talking about.
                                          You dont really know your missing something till you learn you cant do it.
                                          maybe they will add that per your request.  If only it was that easy to get options added.
                                          Maybe CS5 will have it.
                                          Enjoy:  Glenn
                                          • 18. Re: Merge Audio & Video Clips.
                                            digabyte Level 1
                                            I am still trying to get over Adobe's failure to address this issue.
                                            ALL pro editing programs (Avid, Final Cut, etc.) are set up to use a workflow that incorporates utilizing the source and project monitors with files from bins.  You view your master video clip in your Source window, you set your in and out points to select the portion of the video you want to use, and you insert the selected portion onto your composition timeline (the Program window).
                                            You CANNOT do this in Premiere Pro, because Premiere Pro will not link audio and video in the bins.  If you try to use this workflow, only the video is inserted, because the audio is not linked in the bins.  Lift, Overlay, etc. are not an option, because they do not bring the audio along with the video.
                                            The ONLY way to link externally recorded audio with video is on a timeline, and thus everything must be cut and pasted from one timeline to another.
                                            This is ridiculous.
                                            Will someone from ADOBE please explain this?  Is Premiere Pro a professional film/video editing program, or is it not?
                                            • 19. Re: Merge Audio & Video Clips.
                                              Jim_Simon Level 8
                                              Film?  No, I'd say definitely not.
                                              Video?  Yes.  But most video producers record audio and video together, not separately.
                                              • 20. Re: Merge Audio & Video Clips.
                                                digabyte Level 1
                                                But with this simple change (linking audio and video in bins), Adobe Premiere Pro would become the clear choice for editing film.  Especially films shot on RED.
                                                So why not make this simple change?
                                                • 21. Re: Merge Audio & Video Clips.
                                                  Jim_Simon Level 8
                                                  Oh, I'm not arguing against it.  I'm just saying I can understand it.
                                                  You're right, though.  If Adobe wants Premiere to be used on RED proojects, things like this will have to be accounted for.
