5 Replies Latest reply on Aug 30, 2009 9:20 AM by jim2148
    Styles not showing - Premier Elements 3
      No preset styles are present when I launch the 'add title' button; they have always been present prior to this.
      I tried repairing Premier Elements and then a full reinstall - still no preset styles showing.
      Can anyone tell me where I can find the styles on the software CD Rom and into which folder I should place the files when I find them?
        • 1. Re: Styles not showing - Premier Elements 3
          Does this FAQ, from the library at the top of this forum, help?
          http://www.adobeforums.com/webx/.3bbde933
          • 2. Re: Styles not showing - Premier Elements 3
            Level 1
            Steve
            Many thanks for these suggestions - unfortunately they didn't work for me. I have PE 3 and my styles folder is within another one called Presets. However I renamed the workingset.prsl file and relaunched PE 3 but it didn't recreate it.
            What puzzles me is that a full reinstall didn't recreate it either; I then copied workingset.prsl from a backup copy which I had into the Presets/Styles folder and that didn't work either!
            It's not a great problem in theory as one should be able to create a custom style; however in practice I have found the custom style doesn't work - for example though I save it with the Arial font, the retrieved style is always the 18th century font!
            I think the problem may be that I installed Photoshop Elements 2 recently; I may have to uninstall that program and then try another reinstall of PE.
            Thanks for your response though.
            Best wishes
            Nick
            • 3. Re: Styles not showing - Premier Elements 3
              Hey nick,
              you should clear your preferences. You have to delete one file i particular . this is alled "workingset.prsl". Dont rename . just delete it.
              Clear all the fiels from following location:
              My documents\Adobe\Premiere Elements
              Let me knwo if this works.
              • 4. Re: Styles not showing - Premier Elements 3
                Nick,
                I'm highjacking this string to answer Kami-Kaze's response to you. I have had the same problem w/PE3 with a posted message in this forum under "Need help w/PE3 start up error which shuts down program". A response from Paul LS did not help so I searched more and found the recommendation of deleting the "workingset.prsl". I tried that and it worked! Thank goodness, I'm back in business.
                I'm going to update my other string to verify this solution.
                Thanks Kami-Kaze.
                • 5. Re: Styles not showing - Premier Elements 3
                  jim2148
                  I have the same problem. I was glad to find this thread which looked like it could be very helpful to me. I have been unable, however, to reach the link you had suggested (http://www.adobeforums.com/webx/.3bbde933). Perhaps Adobe has closed that page? Does anyone know if the FAQ that originally appeared at that link can be found anywhere else?
                  jim2148
