1 Reply Latest reply on Oct 8, 2008 7:03 AM by Steve Grisetti
    Opacity: PmElm 4.0
      After building a video, rendering, and saving, the opacity of some of the pictures and video's are showed as "media off line". When I check the opacity of the item it is about mid range. If I reset the Opacity to near, but less then 100%, the picture / video is shown correctly. I re render the item, save the file, but the next time I open the file the same problem exists. Usually the problem occurs for 30% to 50% of the items.
      I can manually, item by item, correct the problem, but the correction is not saved.
        • 1. Re: Opacity: PmElm 4.0
          Media offline messages and changed opacity would seem to be two different problems.
          If you save and close your project file, then re-open it, what happens?
          Does the program ask you to re-connect it to "lost" media files?
          Where are these files stored? Are they on your C drive or on an external drive?
