3 Replies Latest reply on Oct 21, 2008 3:32 AM by VideoJohnny
    PE4 MPG Performance Issue Fixed in PE7
      A bit of info
      System
      Intel E8500 Core 2 Duo
      4GB of PC 1066 RAM
      (2) 250 GB Drives in Raid 0, and one single 250GB drives
      Vista 64bit
      Camera Panasonic SDR-h200
      All of the video from the camera is in MPG2 format.
      I have been frustrated with PE4 with the issue where I even for a moment switch to another application, on return to PE4 the program hangs with the hour glass. The length of time that it hangs is proportionate to the length of the project.
      Does anyone know if this issue has been resolved in PE 7? This is an extreme showstopper in PE 4 and I do not want to waste my money on another sub standard version.
        • 1. Re: PE4 MPG Performance Issue Fixed in PE7
          First, make sure you're running Premiere Elements in 32-bit emulation mode, Bill. Running it on a 64-bit operating system has been known to cause all kinds of goofy issues.
          Second, make sure Vista is updated to at least SP1 and with all the latest drivers and newest Quicktime, per the FAQs at the top of this forum.
          http://www.adobeforums.com/webx/.3c057647
          Finally, make sure your operating system is optimized for video editing, also per our FAQs.
          http://www.adobeforums.com/webx/.3bc448a7
          That said, it's really surprising, if your system is fully optimized, updated and tuned up (per http://www.adobeforums.com/webx/.3bc43f9a ) and running in 32-bit mode that you're having any memory issues with version 4. Version 7 is, from all reports, much more stable -- but demands even more RAM space, so if you're having refresh issues with version 4 they're probably going to be even worse in version 7.
          So I'd definitely look into what's causing a computer with that much power to leak resources.
          It could be the RAID set-up. Or it could be that the secondary or tertiary drive you're working on (assuming you've got your project on video files on one of these drives) has been set up in the operating system but not your computer's BIOS. Or that they're formatted FAT32 instead of NTFS.
          Or it could be the nature or size of your video clips. But that's hard to say without knowing more about your system, camcorder and workflow. (Hard drive camcorders certainly don't make the best sources for video editing -- but, with your rig, they shouldn't be fatal, if all others things are set up right.)
          How's that for a lot to think about?
          • 2. Re: PE4 MPG Performance Issue Fixed in PE7
            Level 1
            I ahve worked with several MPEG 2 files in PRe4 and it has not given any problems. Apert from Steve's suggestion I would also like you to select correct project preset. For MPEG it is based to work in Flash Memory based presets.
            • 3. Re: PE4 MPG Performance Issue Fixed in PE7
              VideoJohnny Level 1
              Bill:
              Be patient and the PE7 trial version shoul dbe available shortly. I recommend downloading the trial version and testing it out.
              Other than that - I fully agree with Paul's response.
