8 Replies Latest reply on Oct 17, 2008 4:55 PM by Ozpeter
    H.264
      I am thinking of buying a Samsung SC-HMX20 camcorder. It says it compresses video using H.264(MPEG-4.AVC) main profile format.
      Simply question does premiere elements 7 support this coding and
      has anyone got any experience with this camera.
        • 1. Re: H.264
          Premiere Elements 7 will edit AVCHD hi-def video, Chris. And, from all reports, it does a pretty good job at it too.
          It does require a pretty powerful system, though, to handle these hi-definition, highly-compressed files.
          Here's a list of our system recommendations. If I were you, I'd look into the highest recommendations in the article.
          http://www.adobeforums.com/webx/.59b699a8/2
          • 2. Re: H.264
            Level 1
            Thanks steve
            From what I gather from reading some comments on the web the Samsung doesn't use the AVCHD extended form which Canon and Panasonic use but H.264(MPEG-4.AVC) main profile format. Can I assume this can be read and processed by premiere 7. I understand about the processing requirements.
            Chris
            • 3. Re: H.264
              I don't know enough to comment on that.
              Anybody else have experience with it?
              • 4. Re: H.264
                <Chris_Lytchett@adobeforums.com> wrote in message<br />news:59b6bfaa.1@webcrossing.la2eafNXanI<br />> Thanks steve<br />><br />> From what I gather from reading some comments on the web<br />> the Samsung doesn't use the AVCHD extended form which<br />> Canon and Panasonic use but H.264(MPEG-4.AVC) main<br />> profile format. Can I assume this can be read and<br />> processed by premiere 7. I understand about the<br />> processing requirements.<br /><br /><br />http://en.wikipedia.org/wiki/AVCHD<br /><br />"AVCHD (AVC-HD, AVC HD) video is recorded using the MPEG-4 AVC/H.264 video <br />compression codec."<br /><br />IOW,  AVCHD *is* AVC/H.264 MPEG-4
                • 5. Re: H.264
                  Ozpeter Level 1
                  "AVCHD is a high-definition recording format designed by Sony and Panasonic that uses H.264 (conforming to H.264 while adding additional application-specific features and constraints)."
                  http://en.wikipedia.org/wiki/H.264/MPEG-4_AVC
                  I'm not sure the two are always interchangeable.
                  • 6. Re: H.264
                    Level 1
                    I am using PRE7 to edit AVCHD video in .MTS (from my Canon HF100). I have two issues. The first is that for some reason PRE7 will not "smart render" (i.e. if you want to export it, it re-renders the whole clip even if you've done absolutely nothing to it). IMHO, if you've done nothing to the clip or if all you want to do is snip a little off the beginning and/or the end of the clip, PSE7 should allow you to drop it in the timeline, do your snips, and then "smart render" the result without having to re-render the whole thing from scratch. Other software (from the Pixella ImageMixer software that was included with my camcorder, to Nero to Vegas) support this pretty basic function, and I frankly am stumped why PSE7 doesn't -- particularly since Adobe was so late getting into the AVCHD "game".
                    Second, and related to it, is that I'm getting a "Multiplexing has failed" error when I try to export in "h.264 1920x1080i 30", but there's more on that here: http://www.adobeforums.com/webx/.59b6c530/1
                    --Mav
                    • 7. Re: H.264
                      Level 1
                      <Ozpeter@adobeforums.com> wrote in message<br />news:59b6bfaa.4@webcrossing.la2eafNXanI<br />> "AVCHD is a high-definition recording format designed by<br />> Sony and Panasonic that uses H.264 (conforming to H.264<br />> while adding additional application-specific features and<br />> constraints)."<br />><br />> <a href=http://en.wikipedia.org/wiki/H.264/MPEG-4_AVC><br />><br />> I'm not sure the two are always interchangeable.<br /><br />Given all the strange things that I've seen with MPEG-1, and MPEG-2, I'm not <br />sure that all implementations of AVCHD or H.264 MPEG4 are interchangeable. <br />In fact, I'm pretty sure that people will have interchangable problems with <br />all of the above.
                      • 8. Re: H.264
                        Ozpeter Level 1
                        I don't think Adobe has ever used any kind of smart rendering with any kind of video in any of their software. I agree that it's a pity. However, I can think of a number of PE7 competitor packages which don't smart render - either by design or because they're supposed to and don't. Nero indeed is very good at that, but pretty limited in all other aspects of its operation.
