5 Replies Latest reply on Nov 10, 2008 12:33 PM by Steve Grisetti
    Guidelines for 16:9
    Ed.Macke Level 3
      My Sony MiniDV Handycam has the option of shooting in "widescreen" - which I'm assuming is 16:9.
      So far, I haven't done that because I'm leary of how to process it in PE. FYI, I currently have PE4, but am getting PE7 soon.
      * If I shoot widescreen, are there any "gotchas" upon importing it and editing it in APE?
      * So let's say I've edited my widescreen project...if I create a DVD, what happens when I play that DVD on my non-widescreen TV - does it auto-letterbox like commercial DVDs, or what?
      * What happens if I put that widescreen video up on YouTube?
      * If I run into problems, is there any way to "crop" my 16:9 video into normal 4:3?
      Basically, my fear is that if I shoot 16:9 video, I'm going to end up with squashed video (i.e. 16:9 video scrunched into a 4:3 box) and no way to go back to usable 4:3 footage.
        • 1. Re: Guidelines for 16:9
          Yes, all these things are possible, Ed. And your TV will display your widescreen just as it does commercial DVDs with widescreen.
          You can even crop a widescreen down to 4:3 -- but it wouldn't recommend it. It involves a lot of processing and re-rendering. So I'd recommend you decide before you shoot what format you want to end up with.
          • 2. Re: Guidelines for 16:9
            Level 1
            Ed,
            I agree with Steve. I would also not recommend stepping down from 16:9 to 4:3.
            First you decide what mode you want the result in, shoot in the same mode, edit in same mode using Premiere elements and i can assure you will be glad with the results.
            in case for a same video you require an output in widescreen as well as standard, there are corresponding export presets which you can select and use.
            thanks
            Daniel.
            • 3. Re: Guidelines for 16:9
              Level 1
              I have a Sony mini-DV camera that can film in regular and widescreen and recently started filming in widescreen only.
              Pre El 3 captures, edits, and outputs very well when played on a widescreen or a standard screen. I have found no need to do anything special when planning to view a project on standard screen.
              • 4. Re: Guidelines for 16:9
                I am creating a DVD with several months of video, and the first 5 clips are in standard mode and the remainder in widescreen. Can I create one movie containing both standard and widescreen and then render it? Or do I need to render the two screen sizes separately and combine them afterward? I want the final movie to display in widescreen, and would like black bars on the side of the fullscreen clips so that part of the movie is not distorted.
                • 5. Re: Guidelines for 16:9
                  It's very difficult to handle more than one person's challenges in a single thread, guys. If you've got questions about issues with Premiere Elements, please start your own threads rather than tagging onto an existing one.
