3 Replies Latest reply on Nov 3, 2008 3:48 PM by Robert J. Johnston
    PE7 creates but cant read m2v files
      Working from HDV clips, output a file as m2v ( v because it contained no sound)but when I tried to import the clip into a project I'm told the file type is not supported or I don't have the correct codec installed. I was able to import m2v files when using PE3.
        • 1. Re: PE7 creates but cant read m2v files
          Level 1
          It can however import m2t files which, in this case, are the same pictures but with a soundtrack.
          • 2. Re: PE7 creates but cant read m2v files
            Robert J. Johnston Level 3
            If you ever get your files to load into pre 7, you may run into another problem:
            I can load .m2v files and .mpv files into pre 7, but there is a media pending message that won't go away. When I double-click on the thumbnail in the organizer, there is a message that indexing is going on. However, the indexing progress bar never progresses.
            If I exit out of pre7 and rename the file "ImporterFastMpeg.prm" to "ImporterFastMpeg.prm.xxx" and then start pre7 and open the project again, the media pending messages no longer appear.
            The ImporterFastMpeg.prm file is in c:\Program Files\Adobe\Adobe Premiere Elements 7.0\Plug-ins\en_US.
            The ImporterFastMPEG.prm file is needed for indexing MPEG-2 files for quick access and keeping video and audio in sync.
            • 3. Re: PE7 creates but cant read m2v files
              The good news is that in a Virtual PC the .m2v files load okay into PRE 7, so it would seem that whatever combination of codecs is installed on a PC will influence PRE 7's ability to process various video formats. I have the Mainconcept MPEG Elements plug-in installed on my real PC as well as MAGIX MEP 14+, both of which may install codecs that aren't compatible with PRE 7.
