1 2 Previous Next 64 Replies Latest reply on Feb 26, 2010 5:01 AM by nancy.johnson86
    PE 7 - Mod files from JVC camera importing with errors.
    Level 1
      Hi everyone,
      I was having enormous difficulties with Premiere Elements 4 so I bought version 7 as it listed mod files as a supported type. Well at least PE 7 is actually seeing the mod files and easily importing them. Unfortunately each file ends up with its own unique error - mostly green pixels showing up in the image randomly or even faces or images from other files suddenly appearing in the middle of a different file.
      My project will only go for about 35 mins but it is being created from 3.5 hours of footage. Is anyone else having these sort of issues? Is it just to do with the dreaded mod file, or have other people experienced it in other situations?
      Any help would be appreciated.
      Cheers,
      Stuart
        • 1. Re: PE 7 - Mod files from JVC camera importing with errors.
          Robert J. Johnston Level 3
          The .mod files that people have sent to me with problems all play back without distortion if I change the file extension from .mod to .avi. Actually, I just tack on .avi after .mod.
          I believe that doing this circumvents the indexing phase of MPEG-2 files that Premiere Elements does, which is known to cause distortions in .mod files, however, I have not seen green pixels showing up or other clips appearing where they shouldn't. That sounds more like a memory issue.
          • 2. Re: PE 7 - Mod files from JVC camera importing with errors.
            Level 1
            Maybe it is a memory issue. Maybe the last 6 weeks of trying to sort out this silly looking problem could all just be faulty memory. Man, that would be frustrating. I'll run some test, thanks.
            • 3. Re: PE 7 - Mod files from JVC camera importing with errors.
              Level 1
              yes stuart this looks more like a memory issue to me. I had some problebs with Mod which went away when I started editing the footages in the corrrect proeject presets (Flash Hard disc based)> Mod.
              • 4. Re: PE 7 - Mod files from JVC camera importing with errors.
                Level 1
                I think PE 7 is having trouble handling .MOD files properly. I have a JVC Everio GZ-MG555 and am seeing the same problems as Stuart when importing .MOD files into PE7.
                First off, PE7 does not correctly identify clips recorded at 16:9. I have to "Interpret" the footage or else it's smushed down to 4:3.
                Second, most clips show some artifacting in at least one spot, sometimes two. It lasts for 12-15 frames each time. These glitches show up in the produced movie, too.
                Screenshot: http://screencast.com/t/RWOBhLjt50
                Frame-by-frame: http://screencast.com/t/8Q1rAlMlg
                I'm pretty sure it's not a memory issue, and Robert Johnston's workaround doesn't work for me. When I change the extension to .avi the timeline becomes unresponsive (instead of 2 seconds to build the thumbnails it takes 2-5 minutes) and playback in the PE preview window is extremely choppy. When I capture the video from the camera as DV-AVI instead of importing an .MOD the problem goes away...but this is unacceptable because it reintroduces all the hassles of a MiniDV camera.
                I should also note that the artifacting is not present in the original .MOD files when played back within WMP.
                I had high hopes that PE7 would work well with the accursed .MOD files. But it looks like I'll keep searching for an editor that supports the format...unless anyone else has a suggestion?
                • 5. Re: PE 7 - Mod files from JVC camera importing with errors.
                  Level 1
                  Have you Used a NTSC widescreen Flash based project preset?
                  • 6. Re: PE 7 - Mod files from JVC camera importing with errors.
                    Level 1
                    Fosteronomo that is it exactly. I have been fiddling with my memory sticks and it doesn't appear to be a memory issue. And I agree with everything you said.
                    I really love Premiere Elements but unfortunately this is the camera I have at home and the one I use at work. I'm stuck with mod files.
                    I also tried Power director 7 which works perfectly but doesn't have as many options and only has 2 audio tracks (that is a killer for me, many of my projects use around 10 audio tracks).
                    I'll try the NTSC widescreen preset, in fact I'll try anything. My project is now 3 weeks late and I'm still fiddling.
                    • 7. Re: PE 7 - Mod files from JVC camera importing with errors.
                      Comparing Premiere Elements 2.0 to Premiere Elements 7.0 in regards to MOD files, something has gone wrong in the editing workspace in 7.0.
                      Even after doing a workaround of renaming ImporterFastMPEG.prm to ImporterFastMPEG.prm.tt and deleting all the index files that are created when you add MOD files for the first time to Premiere Elements, there are considerable artifacts when playing unrendered previews. Although, if you render a preview they are gone.
                      However the artifacts are not the same as the distortions I was talking about earlier. The distortions are big blocks of video that shift out of place. Those distortions are gone when you rename .mod to .avi, or if you do the workaround of renaming that ImporterFastMPEG.prm and deleting the index files. But neither of those two tricks get rid of the artifacts during playback of unrendered previews.
                      When you rename .mod to .avi, Premiere Elements uses the Directshow merit system to pick the mpeg and ac3 codecs. For example, if you have FFDShow installed with MPEG2 enabled, Premiere Elements will use that to decode the video. If you don't have a separate ac3 codec installed on your system, then you won't have any audio when you import the file into Premiere Elements. You could enable AC3 in FFDShow Audio and Premiere Elements will use that.
                      Still, even with a 70 minute video clip on the timeline, I don't seen any errant green pixels. And all I have is a Pentium 4, 3GHz, 1 GB RAM with 96MB shared RAM for video.
                      By the way, are we all talking about standard definition or high definition MOD files? I'm only talking about standard definition.
                      • 8. Re: PE 7 - Mod files from JVC camera importing with errors.
                        Level 1
                        This JVC model produces standard def files.
                        I'm using the NTSC HDD/Flash 16:9 project setting.
                        The artifacting that I see in the preview window also shows up in the produced file.
                        I don't have any freeware codec packs installed (I've been warned off them by devs at my company who work in this space)...so that may explain why the avi extension workaround doesn't work for me.
                        Perhaps I should enter a support ticket. I'm brand new to Adobe PE and am just doing the free trial right now, so I'm not inclined to wait around for a dot-one release. I already waited around for v7. Will probably just try some alternatives that are reported to support .MOD files better.
                        • 9. Re: PE 7 - Mod files from JVC camera importing with errors.
                          Those Everio files are notoriously problematic, Foster. But you may have better luck working with them in Sony's Vegas editor.
                          • 10. Re: PE 7 - Mod files from JVC camera importing with errors.
                            Level 1
                            Hello Sirs:
                            I have an Everio GZ-MG465 and of course, problems with .MOD files she produces.
                            The bundled software (I forgot the name) are simply simple.
                            Yes, I went:
                            - Premiere Pro: can't read .MOD. I tried some tricks I found googling but unstable, crashable and still not reading .MOD. It's a pitty.
                            - Premiere Elements 7: yes! it seemed to read .MOD. Wait...those green squared frames...damn, it renders the green artifacts to final vids too!!
                            I opened a case to Adobe. The MOD vids are ok, not artifacts at all, PE7 put them there in two different machines and operating systems. It's a faulty MPEG2 decoding.
                            "Adobe response:
                            Tuesday, 30 December 2008 14:44:59 o'clock GMT
                            Hello,
                            Thank you for contacting Adobe Web Support for assistance with Adobe
                            Premiere Elements 7.0.
                            I understand you are experiencing problems with files imported into
                            Premiere Elements.
                            We are unable to provide technical support for trial products. We do,
                            however, have an online knowledgebase that is helpful for finding
                            solutions for unsupported products. The URL listed below will take you
                            to our knowledgebase:
                            http://www.adobe.com/es/support/
                            We also have User-to-User forums available where you can enter your
                            problem or concerns and see if other Adobe users can offer advice. The
                            URL listed below will take you to our User-to-User forums.
                            http://www.adobe.com/es/support/forums/
                            Customer ID number: 172381748
                            For more information on Adobe products or services please visit us at:
                            http://www.adobe.com/es/support or contact Adobe at +34 91-453-4392.
                            Best Regards,
                            Gregory H.
                            Adobe Web Support"
                            Great response, isn't it?
                            Sony Vegas doesn't read native .MOD from JVC. I tried last version, http://www.sonycreativesoftware.com/moviestudiopp
                            Corel Videostudio PRO X2 does. No artifacts, no problems, I don't like it-poor interface- but I will use it.
                            http://www.corel.com/servlet/Satellite/us/en/Product/1175714228541#versionTabview=tab0&tab view=tab0
                            I will try Pinnacle Studio Plus 12 too
                            http://www.pinnaclesys.com/PublicSite/sp/Products/Consumer+Products/Home+Video/Studio+Fami ly/Studio+Plus.htm
                            Sorry Adobe, you lose a customer. Now I'm more convinced your products are too complicated, resource-demanding and unstable. Well, now I know you didn't care about who are trying your products.
                            I have no relation to Corel, Sony, Adobe or Pinnacle, only want to edit my videos from my JCV.
                            Greetings.
                            • 11. Re: PE 7 - Mod files from JVC camera importing with errors.
                              Level 1
                              Well I had Adobe Premiere Elements 4 and it worked great with my old video camera because it was from DV tapes. I loved working with Elements 4, so I blindly bought Elements 7 because it stated that it worked with mod files. No trial, just wanting to get it all working again. So I am a paying customer and I am going to open a petition with Adobe. I have tried all sorts of work arounds and none of them are acceptable as I just want to place my raw file into a timeline and start working. Most of the efforts I have made create more errors than I started with.
                              I'll let you all know how I go.
                              Stuart
                              • 12. Re: PE 7 - Mod files from JVC camera importing with errors.
                                Level 1
                                Ok Stuart, best luck.
                                I tried Pinnacle Studio 12 Ultimate.
                                Just drag and drop .MOD files from camera to the timeline and everything works fine. No artifacts, quick vids managing and stability.
                                Better production quality than Corel Videostudio PRO X2, I will keep Pinnacle running until Adobe find a solution...
                                Regards.
                                • 13. Re: PE 7 - Mod files from JVC camera importing with errors.
                                  Level 1
                                  I am having the same problems with the "green artifacting" as described above. Using the Everio GZ-MG230. Fortunately, renaming the .mod extension to .avi worked for me. Not sure why I have the proper codec installed, but it's working. The software supplied with my camera, CyberLink Power Producer works as well...just very few features.
                                  I'd like to hope Adobe will fix this problem, seeing as I already spent the money on the software.
                                  -Craig
                                  • 14. Re: PE 7 - Mod files from JVC camera importing with errors.
                                    Even better if Canon would make the Everio produce AVI files, since it seems to uniquely have this problem.
                                    • 15. Re: PE 7 - Mod files from JVC camera importing with errors.
                                      Level 1
                                      I was having the same JVC Everio/Elements 7 problem. I tried renaming the .mod extensions to .mpg and .avi, but still had the green artifacts. After an hour on the phone with Ronald, a VERY helpful Adobe Service Tech, I seem to have a solution that is working on my 5 edit stations here in my AV Lab.
                                      Go to the Adobe Elements 7 folder in your "Program Files" folder and open the "Plug Ins" and "en_US" folders. Find a file called ImporterFastMPEG.prm and remove it. I moved it to the desktop until I test the software totally and make sure this doesn't cause other problems. If you are a brave, go ahead and delete it.
                                      This is working for me, and avoids all that renaming - reprocessing the .mod files. So far, so good!
                                      Good luck...and thank you Ronald!!!
                                      • 16. Re: PE 7 - Mod files from JVC camera importing with errors.
                                        Level 1
                                        Great!
                                        It worked for me too Gary.
                                        It's too late for me, weeks of editing are now in Pinnacle project files I will not come back to PE7.
                                        But of course, very good news.
                                        Of course, a poor response from Adobe Support telling me "no support for trial software" (see a previous post) when removing a file is enough to solve this problem.
                                        Sorry, my money went to Pinnacle.
                                        Next time :)
                                        Thanks a lot Gary.
                                        • 17. Re: PE 7 - Mod files from JVC camera importing with errors.
                                          New Improved Chuck Engels Level 1
                                          It won't be too long before you come back Gary 8)
                                          • 18. Re: PE 7 - Mod files from JVC camera importing with errors.
                                            Level 1
                                            What exactly does this fastimportermpeg do?? I was having the same problems with my everio and once I moved the fastimporter to the desktop all seems well..... I will not delete it though...
                                            • 19. Re: PE 7 - Mod files from JVC camera importing with errors.
                                              Level 1
                                              That is an incredibly good point. I had written off Adobe Premiere Elements as the technical support had rapidly responded to my request with absolutely no help at all. And suddenly here is a solution and Pre 7 is working for the first time ever and I'm stunned. Someone please explain.
                                              • 20. Re: PE 7 - Mod files from JVC camera importing with errors.
                                                Level 1
                                                I too was ready to give up on Elements 7... I think it was just luck of timing and getting a helpful tech (thanks again Ronald!). I do not know what the fastimportermpeg file does exactly, but I still am not seeing any of those green artifacts. I even have gotten brave and deleted this file from some of my workstations.
                                                I do have one other "issue" with Pre7, and that is the way they changed the Timeline to pair the video/audio tracks. I find that Video 2 is paired with Audio 2, and both tracks are above Video 1 and Audio 1. My video editing experience comes from using AVID and Final Cut Pro, and this pairing of the tracks, rather then having all the video tracks above all the audio tracks, is confusing to me and the my students who are just learning video editing. I asked Ronald if there was a way to change the way the tracks are listed on the Timeline, and he said "no". His suggestion was that if this bothers anyone, they should go to: http://www.adobe.com/cfusion/mmform/index.cfm?name=wishform and fill out a "Feature Request". If Adobe gets enough of this request, they may change it in future versions.
                                                Happy Editing all...
                                                • 21. Re: PE 7 - Mod files from JVC camera importing with errors.
                                                  Sbb9505 Level 1
                                                  I just had the same problem, can not import .mod files created by JVC Everio camcorder, into Premiere. After searching for help/reading the Adobe forum, and learning of everyone else's import issues, convert s/w trials, etc. I finally went back to my fall back position.
                                                  1) I created a dvd of the mod files (using the sw that came with the camer, or really anything that creates a dvd format).
                                                  2) I went back to Adobe Premiere Pro, and Using the Capture device (F5) via my Matrox Break-out box/Line in which I hooked to my external DVD player, I am able to bring in all media, exactly like it plays on a dvd player. now I can get back to editing on the one avi file that Adobe created for me.
                                                  I would like to hear from anyone about the cons of doing this. is there a down side/problem? so far, I have not found any.
                                                  • 22. Re: PE 7 - Mod files from JVC camera importing with errors.
                                                    Video_CJC Level 1
                                                    I use to use Adobe Premeir Pro w/my JVC camera.  It took me a long time to figure out the ".MOD" problem.  When I finally figured that out and burned a DVD, another problem was discovered.  When ever the camera would pan in the scene the picture would get very jiddery.  I found out that using video from a HD instead of Mini DV tape you had to change how the fields would be set up.  I guess with HD video you must use "Upperfields First".
                                                    My question is about the same issue.  I found out about deleteing ImporterFastMPEG.prm file from PE7 and imported some video files.  That part worked great, but when I burned it to DVD and played it, I was back to what looked like the "Upperfields First" problem I was having in Premeir Pro.  I looked around in the settings and "Upperfields" is selected but it plays like "Lowerfields First" is what it did.  The reason I switched to PE7 was the fact that it could handle ".MOD" files and was a little simpler than Premeir Pro.  I dont have tons of time to learn Pro right now.  Thanks ahead of time if any one can shed some light on this.
                                                    • 23. Re: PE 7 - Mod files from JVC camera importing with errors.
                                                      Paul_LS Level 4
                                                      By deleting or renaming ImporterFastMPEG.prm you can eliminate Media Pending error message issues but it can impact audio sync. Anyway, if you are capturing standard upper field first material you should use the project preset: "Hard Disk, Flash Memory Camcorders"... this will automatically set the field order for the project to upper field first. Likewise with the high definition presets, it will set upper field first for all the high definition project presets.
                                                      • 24. Re: PE 7 - Mod files from JVC camera importing with errors.
                                                        Video_CJC Level 1
                                                        I did check and I am using the DH camcorder setting w/Upperfield first
                                                        but during play back from a DVD it looks all jiddery when the camera
                                                        is panned. It looks just like the problem I had using Pro, when the
                                                        Lowerfields first are selected. What is the difference between
                                                        capturing video on mini DV or an HD?  Why do you use Lowerfields w/
                                                        mini DV and Upperfields w/HD?  Thanks so much
                                                        Sent from my iPod
                                                        • 25. Re: PE 7 - Mod files from JVC camera importing with errors.
                                                          Paul_LS Level 4
                                                          Can you give some more detail about your camcorder, make and model number?
                                                          Each video frame is made up of two sets of fields each field captured consectutively and interlaced, so each field captured at different times. Which field is displayed first determine if the video is upper or lower field first. By convention DV-AVI is lower field first and HDV MPEG2 is upper field first. Also, most standard definition flash memory, hard drive or DVD camcorders are upper field first. As PE7 has a DV-AVI work flow it expects lower field first video... if you use upper field first you must either use reverse field dominance or the appropriate project preset. The reason i ask your camcorder model number is to confirm that it is infact upper field first.
                                                          • 26. Re: PE 7 - Mod files from JVC camera importing with errors.
                                                            Video_CJC Level 1
                                                            Thank you so much for getting back w/me so soon. The camera is a JVC
                                                            GZ-MG555u. It has a 30G hard drive and 3CCD sensors.
                                                            Sent from my iPod
                                                            • 27. Re: PE 7 - Mod files from JVC camera importing with errors.
                                                              Paul_LS Level 4
                                                              Thanks for clarifying the model number, so yes, it is standard definition, .mod file format. So when you start a project you should select the "Hard Disk, Flash Memory Camcorders" project preset from the project preset list this will ensure that the field order is set correctly for your upper field first video. You should not need to adjust field order in the project timeline. A DVD exported from the project should be fine.
                                                              You say you see video judder during panning? Is this when viewed on you TV or when viewed on a monitor?
                                                              • 28. Re: PE 7 - Mod files from JVC camera importing with errors.
        Video_CJC Level 1
        On the computer, it's perfect. On DVD on my TV is when I see it. If
        the camera is still and not panning in the scene then the video is
        fine. It's like the picture can't update fast enough during a pan vs a
        still shot. This DVD was set up to burn upperfields first.
        Sent from my iPod
        • 29. Re: PE 7 - Mod files from JVC camera importing with errors.
        Paul_LS Level 4
        Can you confirm you used the "Hard Disk, Flash Memory Camcorders" project preset. You need to maintain the correct field order through out the entire editing workflow, from importing, to editing, to burning. If you start with upper field first you need to strat with the correct project preset or correct the field order in the timeline as yoru first step. Other thing, how long is your DVD?
        • 30. Re: PE 7 - Mod files from JVC camera importing with errors.
        Video_CJC Level 1
        The test video is only 6 scenes long and about 5min in time. I'm at
        work now. I'll try another test and go through all the things you told
        me and get back to you. Again thank you for all your time and advice!!!
        Sent from my iPod
        • 31. Re: PE 7 - Mod files from JVC camera importing with errors.
        Paul_LS Level 4
        Hope it goes OK. Let us know how you get on.
        • 32. Re: PE 7 - Mod files from JVC camera importing with errors.
        Video_CJC Level 1
        No luck. I imported 3 files from my camera using the widescreen Hard
        Drive camera setting. I only imported 3 files so as not to take to
        much time rendering. Same results. Thanks
        Sent from my iPod
        • 33. Re: PE 7 - Mod files from JVC camera importing with errors.
        Paul_LS Level 4
        One further thing to try (other than converting the clips to DV-AVI before bringing them into Premiere Elements) is to deinterlace the video on the timeline. So right click on each clip and select Field Order, then select always Deinterlace... this will definately eliminate any field orde issue but will impact the quality slightly.
        OK, assuming the field order is not the issue and you still get juddering during panning when playing on your set-top DVD player there are a couple of other possibilities. One is that the actual DVD and DVD player combo is having issues. Are you using a good brand DVD and what speed are they? Premiere Elements will burn at the maximum speed of the DVD, using lower speed DVDs produces more "compatible" DVDs. Altermatively burning to folder and then burning to DVD with a 3rd party DVD burning software may give better results as you can control the burn speed.
        Another posssibility is that the bitrate of the DVD is too high (as you have only a few clips on the DVD it cant be that the bitrate is too low). DVDs burnt at high bitrate (8Mb/s with Premiere Elements) can have issues with some DVD players when playing back "fast" scenes. You could try to burn at a lower bitrate.. say 6 or 7Mb/s.
        • 34. Re: PE 7 - Mod files from JVC camera importing with errors.
        Video_CJC Level 1
        Thank you for the advice, I will try what you sugested and get back to
        you. As always, thank you much.
        Sent from my iPod
        • 35. Re: PE 7 - Mod files from JVC camera importing with errors.
        Video_CJC Level 1
        The deinterlacing did the trick.  The video was was flawless with any
        movement in the scene.  I did see the video quality was less though as you
        said it would be.  So I guess this proves this is an interlacing problem?  I
        just wonder though, all the video I shoot is in widescreen.  When I import
        the video to the computer, I use the "NTSC hard drive widescreen" setting
        but in the editing window the video is displayed in 4:3.  I have to go to
        the edit tab and change the aspect ratio to widescreen (1.2) for all the
        clips.  Its like the initial setting of widescreen when I imported the video
        didn't take.  So the question is, in that same setting, when your going to
        import, did the "upperfields first" take as well?  Is it rendering
        lowerfields first?  To many standards in my opinion make it so complicated.
        Just to let you know, my DVD burner is a dual-layer HP and I always use
        Verbatim -R DVDs.  I've had the best compatibility with different DVD
        players using Verbatim -R's.  Once a week I record a TV show my wife and I
        like on the harddrive of my computer.  I then edit out the commercials and
        burn a DVD.  It always works so I know the burner and media are OK.
        If you have the time, please let me know the next step.  What do you know
        about SDcopy?  Is that something to look into?
        As always, thank you for your time on this.
        • 36. Re: PE 7 - Mod files from JVC camera importing with errors.
        Cheryl, we are 35 posts into a 6 month old thread. The best way to get a response to your question might be to start a new topic.
        • 37. Re: PE 7 - Mod files from JVC camera importing with errors.
        Paul_LS Level 4
        The aspect ratio issue is another common problem when importing MOD files. Go the clips in the projecy Media Bin. Right click on them, select Interpret footage and select Conform To (guess this is what you are doing). Then select the widescreen format, the clips will then appear widescreen in the editing window. However the upper field first for a flash, hard disk camcorder is correct.
        SDcopy basically jusy sets the extension to MPEG and corrects the aspect ratio flag. You are effectively doing the same thing in PE7 using the Intepret Footage and PE7 accepts the MOD format anyway. So I dont SDcopy will add anything to your workflow.
        Unless you are prepared to convert your footage to DV-AVI I dont think you will be able to do much more than you have done already.
        • 38. Re: PE 7 - Mod files from JVC camera importing with errors.
        Paul_LS Level 4
        We have added a few more pages to the thread over the last week Steve...  so infact it is current...
        • 39. Re: PE 7 - Mod files from JVC camera importing with errors.
        Video_CJC Level 1
        Again thanks for your time. Can you tell me of a good program to
        convert my video to DV-AVI like you mentioned?
        Sent from my iPod
        1 2 Previous Next
