1 Reply Latest reply on Dec 16, 2008 12:03 AM by Paul_LS
    Narrow extra strip at the bottom of captured video
      I used ADVC110 to capture from Sony Hi8. Everything looks fine except I have extra strip of scambled video at the bottom, only tiny width but still annoying. Please advise how to fix it.
        • 1. Re: Narrow extra strip at the bottom of captured video
          Paul_LS Level 4
          You are refering to VHS head switching noise. It will not be seen on a normal TV display. click the More button in the Monitor window and
          select 'Safe Margins'. Anything outside the outer frame will not be seen on a normal TV display.
          However using an LCD TV or if played back on a computer, you will see that area. You could use the "Crop" video effect to trim the scan lines off the bottom. If you scale up the video it adds a lot processing and lowers the video quality.
