1 Reply Latest reply on Feb 21, 2009 10:45 AM by Paul_LS
    Video from DVD is Truncated
    Ole Pa Level 1
      When I get video from a DVD, I get only the first few minutes of the VOB files instead of the entire VOB file. Below is a DIR listing of the VIDEO_TS folder on the DVD. When I import the VTS_03_2.VOB file it shows a duration of 00;05;33;10 in Elements, when there is over an hour when I play the DVD using Microsoft Media Player. If I use the public domain 'ffmpeg' program to convert the VOB file to mpg, then import it into Elements, the duration shows correctly as 01;29;42;24, but the video quality is terrible. Does anyone else have this problem? Is there a setting somewhere that I am missing? It's hard to believe that Adobe would not have tested this!
      Thanks in advance for your thoughts, Jim
      Volume in drive D is DVD_VIDEO_RECORDER
      Volume Serial Number is 3F06-AEEC
      Directory of d:\VIDEO_TS
      02/14/2009 07:58 AM
      02/14/2009 07:58 AM
      02/14/2009 07:58 AM 14,336 VIDEO_TS.IFO
      02/14/2009 07:58 AM 14,336 VIDEO_TS.BUP
      02/14/2009 07:58 AM 51,200 VIDEO_TS.VOB
      02/14/2009 07:58 AM 47,104 VTS_01_0.IFO
      02/14/2009 07:58 AM 47,104 VTS_01_0.BUP
      02/14/2009 07:58 AM 722,909,184 VTS_01_1.VOB
      02/14/2009 07:58 AM 77,824 VTS_02_0.IFO
      02/14/2009 07:58 AM 77,824 VTS_02_0.BUP
      02/14/2009 07:58 AM 1,073,170,432 VTS_02_1.VOB
      02/14/2009 07:58 AM 354,060,288 VTS_02_2.VOB
      02/14/2009 07:58 AM 106,496 VTS_03_0.IFO
      02/14/2009 07:58 AM 106,496 VTS_03_0.BUP
      02/14/2009 07:58 AM 1,073,170,432 VTS_03_1.VOB
      02/14/2009 07:58 AM 1,057,925,120 VTS_03_2.VOB
      14 File(s) 4,281,778,176 bytes
        • 1. Re: Video from DVD is Truncated
          Paul_LS Level 4
          Try this technique for combining your VOB files:
          http://muvipix.com/phpBB3/viewtopic.php?f=38&t=2469
          Have you rendered the timeline before viewing the clip? Or try a short exported section to judhge the real quality.
          Also 1.5 hours on a DVD means the bit rate of the video will be "low"... meaning quality will not be that great.
