14 Replies Latest reply on Sep 2, 2009 8:47 AM by the_wine_snob
    Premiere Elemnts 7 won't make DVDs - NO Error Message
    (Alaister_Macrae) Level 1
      On an Intel P5K motherboard with an Intel core 2 duo processor with 2Gb of Ram under Windows XP Home I can get V1 to burn a DVD using a Sony DV RW DRU-800A DVD burner. Nero also works as does Sonic MyDVD. I have 120GB space free on my C drive and 271GB fre on my video storage drive.
      Version 7, however, simply shuts down, with NO error message of any kind, when I click on Disc burn under the Share Menu. I tried deleting HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E965-E325 etc
      but to no avail.
      As a user of Premiere since the days of Premiere 5 through 6.5 I am very disappointed to find a programme that appears to be no better than Studio.
        • 1. Re: Premiere Elemnts 7 won't make DVDs - NO Error Message
          If you'll work through these troubleshooting steps from the FAQs at the top of this forum and then post your results in as much detail as possible, we'll be more likely to diagnose your problem and recommend solutions.
          http://www.adobeforums.com/webx/.59b5f52c/1
          • 2. Re: Premiere Elemnts 7 won't make DVDs - NO Error Message
            This is aimed a Premiere Pro, but may help - First, work through the steps here http://ppro.wikia.com/wiki/Troubleshooting
            If your problem isn't fixed, report back with the DETAILS asked for in the questions at the end of that link... For question #1 see the note about the FREE http://www.headbands.com/gspot/
            • 3. Re: Premiere Elemnts 7 won't make DVDs - NO Error Message
              I have tried allof the following to no avail.
              All I succeded in doing was deactivating Windows XP Home.
              Troubleshoot system errors and freezes when you burn DVDs or Blu-ray discs (Adobe Premiere Elements 7)
              What's coveredOverview
              Before you begin
              Beginning troubleshooting
              Project troubleshooting
              System troubleshooting
              OverviewThis document can help you resolve problems that occur when you export Adobe Premiere Elements 7 projects to DVD or Blu-ray disc. These problems can manifest themselves in many different ways, including (but not limited to) unrecognized DVD/Blu-ray burners, errors, freezes, and Adobe Premiere Elements 7 unexpectedly quitting. If Premiere Elements 7 returns an error message, search the Adobe Support knowledgebase for specific solution information before performing the tasks in this document.
              Before you beginTo benefit most from this document, perform the tasks in order. Keep track of the tasks that you perform and the results of each, including errors and other problems. Adobe Technical Support can use this information to better assist you if you need to call.
              Always restart the computer after a problem occurs to refresh its memory. Continuing to work without restarting the computer may compound the problem.
              You must be logged on as an administrator to perform some of the procedures in this document.
              Note: The procedures in this document are based on the default interface of Windows, with the exception of the Control Panel. The steps in this document that refer to the Control Panel are in reference to the Classic view. The Control Panel can be switched to the Classic view using the appropriate option located on the left side of the Control Panel.
              Some of these procedures may require you to locate hidden files, hidden folders, or files by their full file names, which include extensions (for example, example_filename.ini). By default, Windows Explorer doesn't show hidden files, hidden folders, and file name extensions that it recognizes. For information on showing hidden files and folders in Windows, see the following documents:
              "Show hidden files, hidden folders, and all file name extensions in Windows Explorer (Windows XP)" (TechNote kb404856).
              "Show hidden files, hidden folders, and all file name extensions in Windows Explorer (Windows Vista)" (TechNote kb404880).
              Beginning troubleshootingThe tasks in this section can help you determine if your problem is related to your project or your system. Before performing any of these tasks, back up all personal files (for example, Adobe Premiere Elements files you created).
              1. Make sure that the system meets the minimum requirements for Adobe Premiere Elements 7.
              Adobe Premiere Elements 7 may not run correctly on a system that doesn't meet the following requirements:
              Intel Pentium 4 or Celeron 1.3GHz (or compatible) processor; Pentium 4 3.0 GHz processor required for HD or Blu-ray. Dual Core processor required for AVCHD
              Microsoft Windows XP with Service Pack 2 or Windows Vista
              For Windows XP: 512MB of RAM (1GB required for HDV, AVCHD or Blu-ray)
              For Windows Vista: 1GB of RAM (2GB required for HD or Blu-ray)
              4.5GB of available hard-disk space
              Color monitor with 16-bit color video card
              1,024x768 monitor resolution at 96dpi or less
              Microsoft DirectX 9 or 10 compatible sound and display driver
              DVD-ROM drive (compatible DVD burner required to burn DVDs; compatible Blu-ray burner required to burn Blu-ray Discs)
              DV/i.LINK/FireWire/IEEE 1394 interface to connect a Digital 8 or DV camcorder, or a USB2 interface to connect a DV-via-USB-compatible DV camcorder (other video devices supported via the Media Downloader)
              Quicktime
              Note: To check basic system information, such as processor speed and how much RAM is installed, choose Start > Control Panel > System.
              2. Make sure that the project size does not exceed disc capacity.
              If the project is larger than the maximum capacity of the DVD or Blu-ray disc, then you won't be able to export it to DVD or Blu-ray disc. If the project exceeds disc capacity, then Adobe Premiere Elements 7 displays a warning message and the Burn button is unavailable. A standard single-layer DVD should hold up to 2 hours of video. A standard dual-layer DVD should hold up to 4 hours of video, depending on your transcode settings. A standard single-layer Blu-ray disc should hold up to 4.5 hours of high-definition (HD) video or 11 hours of standard-definition (SD) video. Premiere Elements only supports the single-layer Blu-ray format.
              3. Burn the project to a DVD folder.
              This step is only applicable if you are attempting to burn a DVD. If you are attempting to create a Blu-ray disc, please proceed to Step 5.
              If Adobe Premiere Elements 7 successfully creates a DVD folder on the hard disk, then the problem is most likely not being caused by your project. Continue your troubleshooting with System Troubleshooting (step 8).
              If Adobe Premiere Elements 7 does not successfully create a DVD folder on the hard disk, then the problem may be with your project. Continue your troubleshooting with the next step.
              4. Build a DVD folder from the sample project in the tutorial.
              Start Premiere Elements and at the welcome screen choose tutorials. This will load the sample movie project.
              Select the Share tab and choose Disk. Change the Burn to option to Folder (4.7 GB) or Folder (8.5 GB).
              Click Burn.
              If you can build a DVD folder from the tutorial project, then continue troubleshooting with Project Troubleshooting (Step 5).
              If you cannot build a DVD folder from the tutorial project, then continue troubleshooting with System Troubleshooting (Step 8).
              Project troubleshootingIf you have determined the problem to be with your project, then try the following troubleshooting tasks.
              5. Render the project timeline before you export to DVD or Blu-ray disc.
              Prerendering the project timeline helps you to detect and eliminate problems with particular project media or effects. If an error or problem occurs when you render the timeline, then troubleshoot the media or effect in the timeline.
              6. Troubleshoot clip media used in the project.
              Open the project in Adobe Premiere Elements 7.
              Save your original project and create a test project; Choose File > Save As and rename the project test.
              Delete the clip media from approximately the last half of your timeline.
              Select the Share tab and choose Disk. Select the DVD or Blu-ray settings you want, and then click Burn:
              If the error happens again, then repeat steps 3 and 4, deleting approximately half of the remaining clip media from the timeline until the error no longer occurs.
              If the error no longer occurs, then add back the clips that you removed in small groups and test after each addition. When the error happens again, one of the most recent clips added back to the timelines is the cause.
              Once you identify the problem clip, return to your original project and remove and replace the problem clip media.
              Save the corrected version of the project and export it to DVD or Blu-ray disc.
              7. Export the project as a Microsoft DV AVI file, and then import it into a new project.
              Export the project timeline to the hard disk as a Microsoft DV AVI file, and then import the file into a new Adobe Premiere Elements 7 project before you export it to DVD or Blu-ray disc.
              System troubleshootingIf you have determined that the problem is with your system, then try the following troubleshooting tasks.
              8. Completely erase all DVD or Blu-ray discs before exporting.
              If you use a rewritable DVD or Blu-ray disc, use a third-party utility to perform a full erase of the disc before you export.
              Note: You may experience other errors if you use rewritable DVDs. If you use rewritable DVD discs, and erasing the disc does not res
              • 4. Re: Premiere Elemnts 7 won't make DVDs - NO Error Message
                I have tried all of the following to no avail. I also found that exporting to mpeg caused the same results, ie shut down with no warnig message.
                11. Disable startup items and services.
                Antivirus software, firewall software, anticrash software or other applications and services that are typically loaded when Windows starts may interfere with the burning process. You can temporarily disable nonessential startup items and services from loading by using the Windows System Configuration Utility.
                To start Windows in a simplified mode:
                Quit all applications.
                Do one of the following:
                On Windows XP, choose Start > Run, and type msconfig in the Open text box. Click OK.
                On Windows Vista, choose Start, type msconfig in the Search text box, and then press Enter.
                Write down all unselected items under the Startup and Services tabs.
                Click the General tab, and choose Selective Startup.
                Click the Startup tab and select Disable All.
                Click the Services tab and select Hide All Microsoft Services.
                Select Disable All then reselect FLEXnet Licensing Service. If you are unsure whether an item is essential, leave it deselected (disabled).
                Click Apply, and restart Windows for the changes to take effect.
                Note: Upon restart, you'll be notified that the System Configuration utility has made changes to the way that Windows starts up. Click OK. When the System Configuration utility appears, click Cancel.
                Right-click icons in the Notification Area and close or disable any startup items that are still active.
                Try to recreate the problem.
                If the problem no longer occurs, then one of the startup items conflicts with Adobe Premiere Elements 7. Re-enable startup items one at a time, testing each time until you determine which item conflicts with Adobe Premiere Elements 7. Contact that item's manufacturer to see if an update is available.
                If the problem recurs, then startup items are not the cause of the problem and you can re-enable them.
                To re-enable startup items:
                Click the General tab, and choose Normal Startup.
                Deselect any items that you wrote down in Step 3 of the previous section.
                12. Disable the IMAPI CD-Burning COM Service. (Windows XP only)
                Note: In Windows Vista, the IMAPI service is implemented differently and is not loaded as a background service.
                The native Windows CD burning service (IMAPI CD-Burning COM Service) may cause conflicts when you try to export to a DVD or Blu-ray disc from Adobe Premiere Elements 7. You may need to disable this service before you export a DVD or Blu-ray from Adobe Premiere Elements 7.
                Note: Disabling the IMAPI CD-Burning COM Service disables the ability of Windows XP to natively burn CD-R/RWs.
                To disable the IMAPI CD-Burning COM Service:
                Choose Start > Settings > Control Panel, and then double-click Administrative Tools.
                Double-click Services.
                Right-click IMAPI CD-Burning COM Service and choose Properties.
                If the service status is Started, click the Stop button.
                Choose Disabled from the Startup Type menu.
                Click Apply, and then click OK.
                Try to export an Adobe Premiere Elements 7 project to DVD or Blu-ray disc. If you cannot export a project to DVD or Blu-ray disc without error, then you can re-enable the IMAPI CD-Burning COM Service. To re-enable the IMAPI CD-Burning COM Service, repeat steps 1-6, but choose Automatic from the Startup Type menu in step 5.
                13. Switch the DVD drive controller to DMA Mode.
                DMA (Direct Memory Access) and PIO (Program Input/Output) are used for data transfer. Drives that are set to use PIO instead of DMA require more CPU cycles and transfer data more slowly than drives using DMA. By selecting DMA for the DVD or Blu-ray drive, you may increase the drive's performance and reduce the likelihood of errors.
                To select DMA for the DVD or Blu-ray drive:
                Note: You must enable DMA in the system BIOS before you can complete this procedure. See the computer or motherboard documentation for additional information.
                Choose Start > Control Panel.
                Double-click System.
                On Windows XP, choose the Hardware Tab and click Device Manager.
                On Windows Vista, choose Device Manager in the Tasks pane.
                Expand IDE ATA/ATAPI Controllers and double-click an IDE controller.
                Click the Advanced Settings tab.
                On Windows XP, choose DMA If Available from the Transfer Mode menu.
                On Windows Vista, select the Enable DMA checkbox.
                Repeat steps 5-6 for each IDE controller in the IDE ATA/ATAPI Controllers list.
                14. Update the DVD/Blu-ray burner firmware.
                Contact the DVD/Blu-ray burner manufacturer for the most recent firmware available for your burner.
                15. Update the video card driver.
                Many video card manufacturers frequently update their software drivers. If you haven't recently updated the video card driver, contact the video card manufacturer for an updated driver, or download one from the manufacturer's website. (To determine the manufacturer of a video card, view the card's properties in Device Manager.)
                16. Disconnect additional DVD or Blu-ray burners.
                If you have multiple DVD or Blu-ray burners connected to the computer, then they may cause errors in Adobe Premiere Elements 7. Disconnect any additional DVD or Blu-ray burners before you build an Adobe Premiere Elements 7 project to ensure that other burners don't interfere with the burner you use to build a project.
                17. Export the project using one of the DVD or Blu-ray compatible presets.
                If you are trying to create a DVD, export the project as a standard DVD MPEG-2 file and use an alternative DVD authoring application to create a DVD. If you are trying to create a Blu-ray disc, export the project using one of the H.264 or HD presets and use an alternative Blu-ray authoring application to create your Blu-ray disc.
                To create a DVD-compliant MPEG2 file from Adobe Premiere Elements 7:
                Select the Share tab.
                Choose Personal Computer.
                Select MPEG from the list of available formats.
                Choose one of the NTSC DVD or PAL DVD presets from the Presets popup menu.
                Enter a name and location for the file.
                Click Save.
                To create a Blu-ray-compliant file from Adobe Premiere Elements 7:
                Choose one of the H.264 or HD presets from the Presets popup menu.
                Click Save.
                If you cannot burn a DVD or Blu-ray disc in another application, then the DVD or Blu-ray burner or associated drivers may be causing the error.
                If you can burn a DVD in another application, then continue with the troubleshooting tasks in this document. Alternatively, if you were successful in creating a DVD folder, then you can use another DVD authoring application to burn those files to DVD.
                18. Disable Windows AutoPlay.
                The Windows AutoPlay feature may conflict with the DVD/Blu-ray burning process and cause errors. For more information about disabling AutoPlay, see Windows Help.
                19. Refresh the DVD drivers list in the Windows registry.
                Note: This task applies to DVD drives only. If your issue is related to a Blu-ray drive, skip this task.
                Installation of other DVD- and CD-burning applications may alter the drivers list in the Windows registry. Refreshing this list may resolve problems accessing the DVD burner from Adobe Premiere Elements 7.
                Disclaimer: The registry contains system-related information that is critical to your computer and applications. Before modifying the registry, be sure to make a backup copy of it. Adobe doesn't provide support for problems that arise from
                • 5. Re: Premiere Elemnts 7 won't make DVDs - NO Error Message
                  <Alaister_Macrae@adobeforums.com> wrote in message<br />news:59b80697.3@webcrossing.la2eafNXanI<br /><br />> I have tried all of the following to no avail. I also<br />> found that exporting to mpeg caused the same results, ie<br />> shut down with no warnig message.<br /><br />Have you tried exporting your project as a DV-AVI?<br /><br />If you do that and the process ends for any reason, you should still obtain <br />a partial DV-AVI that ends in the general vicinity of the part of your <br />project that is causing the problem. You can use this information to remove <br />or alter the part of your project that is actually causing the problem.
                  • 6. Re: Premiere Elemnts 7 won't make DVDs - NO Error Message
                    I can export to avi tape but not to dvd or mpeg.
                    • 8. Re: Premiere Elemnts 7 won't make DVDs - NO Error Message
                      Steve,
                      I tried following your directions as asked but on attempting to export as an mpeg file it shut down again with no warning mesage. It won't make flash videos either. In fact all I can get is a DV avi file on copmputer or out to mini DV tape. I have also tried everything else as you will see from my earlier postings.
                      Where do I go from here to get a fix?
                      • 9. Re: Premiere Elemnts 7 won't make DVDs - NO Error Message
                        There are a number of steps listed in the article I linked you and, if you could post your results for each step in detail, I may be better able to help you.
                        Otherwise, all I can do is suggest updating your firmware, particularly Quicktime.
                        http://www.adobeforums.com/webx/.3c057647/2
                        And run regular, weekly maintenance on your computer.
                        http://www.adobeforums.com/webx/.3bc43f9a/0
                        And, when you launch Premiere Elements, try holding down the left side Ctrl+Alt+Shift keys to clear any corruptions in the file.
                        These are general maintenance issues, but things everyone should do anyway, even if their computer is brand new. I do them every Saturday morning, and Premiere Elements 7 runs flawlessly on my computer.
                        • 10. Re: Premiere Elemnts 7 won't make DVDs - NO Error Message
                          Level 1
                          <Alaister_Macrae@adobeforums.com> wrote in message<br />news:59b80697.5@webcrossing.la2eafNXanI<br /><br />> I can export to avi tape but not to dvd or mpeg.<br /><br />Interesting. You probably found a bug in APE7's  MPEG export code.<br /><br />You can always convert DV-AVIs to other formats using external software such <br />as Super!
                          • 11. Re: Premiere Elemnts 7 won't make DVDs - NO Error Message
                            Solution found.
                            By removing everything except Windows, re-starting, installing latest version of Quicktime, re-starting, installing Elements 7, re-starting and then re-installing the rest. It's very time consuming but it eventually works and one can export mpeg as well as burn DVDs.
                            Alaister Macrae
                            • 12. Re: Premiere Elemnts 7 won't make DVDs - NO Error Message
                              Answer.
                              Alaister Macrae
                              • 13. Re: Premiere Elements 7 won't make DVDs - NO Error Message
                                cns518
                                using premiere elements 7 I created a 2 1/2 min video using 21 still images with background music and narration.  when I tried to burn a dvd 7 locked up and I got a "transcoding error".   when I tried to save it as mpeg or avi, I got an "out of memory" error.  I have 4 gb of memory and 250gb of free hard drive space using XP media edition.  when 7 didn't work I created exactly the same project on version 2 and it worked perfectly.
                                I found the problem on v7 was the size of the still images.  I had to open each image in photoshop and change it's size to 720 x 1080, just like each image was a video frame.  It was a major pain, especially if you want to save the images in their original size as well.
                                when I did that 7 would burn to dvd and save to mpeg just fine.  my question is why the newer version takes a step backward?   so far 7 just isn't worth the bother.  On the adobe website check out KB404007 for their explanation of the problem.
                                • 14. Re: Premiere Elements 7 won't make DVDs - NO Error Message
                                  the_wine_snob Level 9
                                  This is the WORKFLOW that I use for all still images in PrE, or PrPro. As I am working with copies of the original Assets, having them in different sizes for different usages is not an issue.
                                  Hope that this helps,
