3 Replies Latest reply on Mar 6, 2009 10:01 AM by Steve Grisetti
    Is there quality degradation when going avi to VOB and back?
      Long time home editor with Pinnacle and now Adobe. But things I have always wanted to know:
      Storage solutions
      If I burn a DVD movie and want to bring that movie back into Premiere will the quality degrade in the new project?
      Can I get more video onto a DVD as a DVD movie than storing the avi on DVD?
      If so, I would be inclined to store video in DVD movie format as long as I can get the quality back when I grab the VOBs for other editing.
      Phil
        • 1. Re: Is there quality degradation when going avi to VOB and back?
          the_wine_snob Level 9
          Yes. If you start with a DV-AVI Type II file, you have a very lightly compressed file. When you go to DVD-Video, you have compressed to MPEG-2, but with SD material, played on a TV, you will still have an image, that is as good as it gets. Now, you bring that MPEG-2 into Premiere to re-edit, and the file will either be converted to DV-AVI Type II, by Premiere, or by a 3rd party program. It will be slightly degraded at that point. Where the hit really comes in is when you then Export that to DVD-Video via MPEG-2 compression yet again.
          For my archiving, I keep the tapes, then Archive (I use Premiere Por's Project Manager, but PE has Archiver), to keep my Captured DV-AVI Type II's, plus the full Project. These go onto a series of 2TB external hard drives. If I anticipate needing to just burn additional DVD's later on, I'll burn to a folder, and keep that intact also. Otherwise, one can make a duplicate DVD from a "master," and not have to re-Transcode, or re-Compress.
          • 2. Re: Is there quality degradation when going avi to VOB and back?
            Level 1
            I did get the contents from a DVD-video into PE by using the Media Downloader under file and then took those VOB files into the sceneline and created an avi and the video was "jumpy".
            I know people have asked about archival needs in the past. I guess it comes down to redundancy.
            Is there a collective opinion on when to duplicate DVDs to avoid material degradation?
            • 3. Re: Is there quality degradation when going avi to VOB and back?
              Jumpiness is not a sign of degradation. It's a sign of unsynchronized interlacing.
              If you imported the DVD footage into a Premiere Elements project that uses the DVD settings, the field order will be automatically reversed and you will not see this jumpiness in your output.
              If you used the DVD footage in a standard DV project, you will need to manually reverse the field order by right-clicking on each clip on the timeline and selecting the Field Order option.
