1 2 Previous Next 70 Replies Latest reply on Nov 21, 2009 9:56 AM by microdobe
    Reader 9 PDF printing problems
      I have a Kyocera FS-C5015N. When I print any multi-page PDFs to the FS-C5015N, only the first page comes out or nothing at all. I have tracked the problem down to Adobe Reader 9. I say this because I can successfully print multi-page PDFs using version 8.2. But I cannot with v9. I have downloaded the latest drivers from Kyocera's website. Same problem. I can successfully print with Word, Excel, etc. just not Adobe Reader v9. Any ideas on what I can do to resolve this issue? Thanks.
        • 1. Re: Reader 9 PDF printing problems
          MichaelKazlow MVP & Adobe Community Professional
          Peter,
          What OS? If you are running windows, then there is a PCL driver and a
          postscript driver. Which are you using? Have you tried the other?
          Mike
          • 2. Re: Reader 9 PDF printing problems
            Level 1
            We are using Windows XP SP3 with all the latest patches. We are using the latest PCL driver from Kyocera. We are not printing anything that would need postscript. So we need to stick with the PCL driver. Again, if I print from Adobe Reader 8, PDFs print just fine. When I print from Adobe Reader 9, that is when the documents don't print properly. Any ideas?
            • 3. Re: Reader 9 PDF printing problems
              Peter,
              I have found when using certain applications that the PCL driver is
              better to use on others the PS is better to use. I don't have a
              prejudice against either driver. Give the PS driver a chance if it cures
              the problem, I'd recommend using it. While it may be better to have a
              fix for the PCL driver, I sure don't know of it. There is no reason to
              avoid the PS driver, just because you don't generally need it.
              Mike
              • 4. Re: Reader 9 PDF printing problems
                Level 1
                I tried the Post Script drivers, same problem (only the first page of a multi-page PDF prints). Any other thoughts?
                • 5. Re: Reader 9 PDF printing problems
                  Peter,
                  At this point I've only got a few things to ask and check. They are
                  obvious, but I'm at the same loss you are.
                  1) In the print dialog box there is a setting for printing a single page
                  or a range of pages. Are you sure it is not set for one page?
                  2) Could there be anything in the printer setup dialog box that is
                  telling the printer to print only the first page?
                  3) Try installing the generic postscript printer. Can you print more
                  than one page? If not, the fault probably lies somehow within your
                  printer OR perhaps some setting within Reader is stuck. I'd recommend
                  removing all Acrobat/Reader programs on your computer. Use the Microsoft
                  Installer Cleanup to make sure nothing is left over. Then install Reader
                  9 and see what happens.
                  Mike
                  • 6. Re: Reader 9 PDF printing problems
                    Level 1
                    The print dialog box is set to print "All."
                    I can print multi-page documents from Word, Excel, Publisher just fine to the printer. If there was a setting on the printer to only print the first page, it would affect all programs.
                    I can print just fine from Adobe Reader 9 to all other printers I try. There is no problem with Adobe Reader 9 printing only one page. Moreover, I can print multi-page PDFs just fine with Adobe Reader 8.
                    When you say "generic post script driver," what driver are you referring to?
                    • 7. Re: Reader 9 PDF printing problems
                      Level 1
                      I figured out a work around to my problem. Going to File -> Print -> Advance -> Print as Image works. My question now is there a way to change this setting via the registry? That is, so that "Print as Image" is the default?
                      • 8. Re: Reader 9 PDF printing problems
                        Print as image rasterizes things at your computers end. Either you will
                        end up with things printed at too low a resolution or too high if you do
                        this all the time. Let's try this a bit longer. If you go to the
                        installing a postscript printer, there should be an option for a Generic
                        Postscript printer.
                        Mike
                        • 9. Re: Reader 9 PDF printing problems
                          Level 1
                          I am not sure what you mean by there is a point where I can select a generic post script driver. I have the printer installed and I can change the driver. What should the driver be changed to?
                          • 10. Re: Reader 9 PDF printing problems
                            I have a similar problem to Mike Kazlow. I deployed Adobe Reader 9 to all computers on my network using the deployment wizard and Group Policy. Now, nobody can print more than the first page of a multi-page document. The exception (and unpopular workaround) is to print the PDF to a Microsoft XPS file and print that.
                            Our printers
                            The natives are taking up torches and pitchforks to demand that I restore Adobe Acrobat Reader 8.2. I hope to find a solution soon.
                            - Joe
                            • 11. Re: Reader 9 PDF printing problems
                              Level 1
                              Joe-
                              Actually, I am (Peter) the one who posted this originally. What kind of printers are you using? I find that the problem with printing multi-page documents only occurs on certain printers. I did find a workaround to this. You can have the users go to "Advanced" after they click on print and then select "print to image." Then have them print the documents. I've found this works in all cases. The printing is slower, but at least the PDFs print. I hope Adobe releases a permanent fix to this issue pronto.
                              • 12. Re: Reader 9 PDF printing problems
                                I seem to be having the same problem with Reader 9 as well. Everyone else in the office seems to be able to print fine, but I can only print the first page of a pdf. When I print to image I have black boxes printing in the margins. I can print one page at a time by selecting a specific page, but it won't print a range. Very inefficient when trying to print a large document. C'mon Adobe, give us a fix.
                                • 13. Re: Reader 9 PDF printing problems
                                  I have the Kyocera KM-C3225E KX and the very same problem with Adobe Acrobat Reader 9. Can I download Reader 8 somewhere while Adobe is working hard on finding a fix?
                                  • 14. Re: Reader 9 PDF printing problems
                                    <ftp://ftp.adobe.com/pub/adobe/reader/> will take you to the virtual <br />land where all versions of Reader exists. You need to choose platform, <br />version, and language (enu for english).<br /><br />Mike
                                    • 15. Re: Reader 9 PDF printing problems
                                      We are having the same issue with Acrobat Reader 9.0.0 and a Canon imageRUNNER C3100. The first page will print and thats it. On our other desktops(all running windows xp pro with sp3) version 8 has no issues. I have downloaded and insalled the latest PS3 drivers from Canon as well we had the Canon service reps come in and update the unit with all the latest firmwares and still no go. Adobe if you are our their plese post a fix. Anyone else have anything to ad other than pringing as an image. This is way to slow for our office to use. a 35 page text pdf take 30 minutes to print.
                                      • 16. Re: Reader 9 PDF printing problems
                                        Level 1
                                        Regarding the "print only the first page" problem, we use Dell W5300N printers, using the latest PS driver from Dell.
                                        Foxit Reader has no problems.
                                        • 17. Re: Reader 9 PDF printing problems
                                          We are having the same issue with Adobe Reader 9.0 and our Toshiba e-studio 281c. Only the first page of a multi-page document will print. It worked great until we updated to 9.0!! Help.
                                          • 18. Re: Reader 9 PDF printing problems
                                            I've had the same problem, ever since I installed Adobe Acrobat 9.0 Pro. It will only print the 1st page on both the Canon ImageRunner C3220 and Kyocera KM4050 printers. The problem is not with the printer drivers - the problem is with Adobe!
                                            My fix has been to open the document using Acrobat Reader (I have 7.0)and it prints fine. Now I'm seeing the same problem on the forums with Acrobat Reader 9.0.
                                            I'm refusing to purchase or download any future upgrades until Adobe acknowledges and fixes this problem. Currently the fix is to revert back to any version prior to 9.0 and you will be able to print just fine.
                                            • 19. Re: Reader 9 PDF printing problems
                                              I have to report the same problems. Computers in theis office using Windows 2000 and XP SP3 display the samre problem printing to a Kyocera prinetr, but print normally on our Brother, Lanier and HP laserjet printers.
                                              • 20. Re: Reader 9 PDF printing problems
                                                We also have the same problem with the full version after upgrading from adobe pro 7 to adobe pro 9 today. OS is xp with sp3, ? No problem before?
                                                • 21. Re: Reader 9 PDF printing problems
                                                  Has anyone found a better solution to this problem than clicking print as image? possibly a more permanent solution?
                                                  • 22. Re: Reader 9 PDF printing problems
                                                    I am having the same problem with a Kyocera KM3232e and there is a workaround for it, although it has not fixed the problem completely.
                                                    This fix assumes you are using the kyocera KX driver (this is a universal driver so most kyoceras use this driver.
                                                    If you go into the printers and faxes folder, right click on the kyocera printer and select properties, then go to device settings, there will be a button on the screen called "PDL". Note, if the driver is installed on a server and you are on the client pc, this will be greyed out. You will have to log onto the print server to change the setting.
                                                    When you click on the button you then be able to "select PDL:" It will probably be set to KPDL. click on the "settings" button and deselect the "allow data passthrough" button. Click Ok until you have closed the kyocera printer window down.
                                                    This forces the adobe reader to do more of the processing and it seems to allow the document to print fully. In my particular case this causes the print quality to drop markedly but I think that is a separate issue!!!!
                                                    Dave
                                                    • 23. Re: Reader 9 PDF printing problems
                                                      I have an HP550C which will only print the first page of a multi-page doc correctly. With Ver 9, follow-up pages are printed with gibberish characters. With another PC with Ver 8, all printing works properly.
                                                      • 24. Re: Reader 9 PDF printing problems
                                                        Level 1
                                                        Hello : I have a HP 4100 deskjet and it will not print the files eather , i found that i can get it to print 10 pages at a time , but they are all written in reverse . So you can not read them , i know a lot of people need to be able to write there own files , but i just need to be able to read and print PDF files . I had adobe 8 but it would not print the CD file Manual sent to me for the DVD player and had me up grade to adobe 9. Problem is if the file was written with adobe8 you have to have it to print it and if it was written with 7,9, then you need those to be able to print the information that was written be those programs . Adobe need to have just one that will read and print all forms .
                                                        • 25. Re: Reader 9 PDF printing problems
                                                          Level 1
                                                          Hello
                                                          Found a solution that get around the problem of only printing the first page from another forum, which i can no longer find? It involves changing setting in acrobat, file print, advanced, select postcript options, and then ahange 'Font and Resource Policy' to Send for Each Page?
                                                          • 26. Re: Reader 9 PDF printing problems
                                                            We are having the same issue with Reader 8 or 9 and Canon IR 3200. I can use Adobe Standard 6 without an issue. However I am not going install my single copy of Adobe 6 on 150 computers.
                                                            • 27. Re: Reader 9 PDF printing problems
                                                              Level 1
                                                              JackOc :
                                                              Hello ! I had to download the Generic Post Script Printer at Adobe , then the pages would print OK and not in Reverse . But my HP Printer would only print 5 pages at a time, as it is for home use and not commercial so it does not have enough memory to take all the 89 pages i was trying to print from a CD for the DVD-VCR player that we just bought . You may want to try that ! as it took me 4 days to figure it out . The Generic Post Script Printer is free from Adobe and i think they are listed under Products . But if you can not find it let me know and i will post the link for you .
                                                              • 28. Re: Reader 9 PDF printing problems
        Level 1
        Hello : Here is the Link for that post script driver
        http://www.adobe.com/products/printerdrivers/
        • 29. Re: Reader 9 PDF printing problems
        Level 1
        I have the same problem but not with postscript. I'm using an inkjet. Reader 9 prints only the LAST page of a pdf. Printer dialog says printing 1 of 1 no matter how big the doc is.
        Mac Preview prints multi-page pdfs just fine.
        I couldn't use Reader 8 because it always crashed. Now I'm not going to use Reader 9 either. I'm trying to solve too many other Adobe failures to bother with this.
        Unless there's a simple solution, I'll use Preview or Acrobat Pro.
        • 30. Re: Reader 9 PDF printing problems
        Thanks DaveGM. That fixed our problem with printing to our Kyocera. Thank You!!!
        • 31. Re: Reader 9 PDF printing problems
        I am having the same problem, We tried print a range of pages using Reader 9.0 and regardless of the range given, it will only print the first page of the range. We have over 15 printers HP Laserjets and Canon iRs on our network using PCL, PS and UPF drivers. It behave exactly the same way on every printer we tried.
        While using the same PDF document, we tried the same print range operation using Adobe Reader 8.x and it printed the complete range of pages with no problems!!
        This translate that is NOT a driver issue or anything of that nature, IT IS SIMPLY ADOBE READER 9 WENT OUT TO THE MARKET WITH LOTS OF BUGS!!!
        Adobe please fix the problem!!!
        • 32. Re: Reader 9 PDF printing problems
        Level 1
        • 33. Re: Reader 9 PDF printing problems
        Currently using Windows XP Professional machines with Adobe Acrobat 9 Pro.
        Users cannot print PDF documents in Adobe Acrobat 9 Pro in Colour to the TOSHIBA eStudio 3150c machine - i.e. The 2nd page doesn't print or double-sided printing doesn't work or you get errors when you try to print the PDF document.
        I've found these instructions help (see below), but really need a FIX for this recurring problem!!
        Change the font and resource policy to Send for Each Page.
        Note: Your printer drivers must be PostScript capable to use this procedure.
        Open Acrobat or Adobe Reader.
        Choose File > Print.
        Click the Advanced button.
        The pop-up window that appears will look different depending on what print driver you have installed. If your driver is PostScript capable, then there should be a PostScript Options section.
        In the PostScript Options section, change the "Font and Resource Policy" dropdown to "Send for Each Page".
        The document then should print as per normal.
        • 34. Re: Reader 9 PDF printing problems
        same problem. but I can print each page one by one.
        • 35. Re: Reader 9 PDF printing problems
        If you can print each page, perhaps the printer needs more RAM or
        perhaps your computer system is running low on resources (could be RAM,
        free hard disk spsce or for earlier versions of Windows system pointers).
        Mike
        • 36. Re: Reader 9 PDF printing problems
        Level 1
        It is not a RAM issue for us. The reason I say this is that I can print PDFs just fine with Adobe Reader 8. That is to say, I uninstall Adobe Reader 9 from a machine, install Adobe Reader 8, and tada, the multi-page PDF prints just fine. However, with Adobe Reader 9 installed we can only print one page at a time on multi-page PDFs. All multi-page PDFs we have tried are affected by the bug in Adobe Reader 9. Since so many different users are having the SAME problem with various printer models, it does seem the issue is with Adobe Reader 9. Will Adobe please acknowledge this problem and let us know when a fix will be available?
        • 37. Re: Reader 9 PDF printing problems
        Nemuri13 Level 1
        Peter...this is very simply a driver issue. Not ALL printers are having this issue. It seems to be certain Kyocera, Canon, and HP printers. Also if you will look at one of the previous posts the issue was resolved by changing settings in the PRINTER! I am sure Adobe is most likely trying to code a more forgiving solution but there is probabably not an update in the near future.
        • 38. Re: Reader 9 PDF printing problems
        Level 1
        I do realize that not all printers are affected. However, the problem is clearly with Adobe Reader 9. The reason I say this is that the problem does NOT exist with Adobe Reader 8. The problem ONLY occurs with Adobe Reader 9. Furthermore, I am not sure what specific resolution to this printer you are referring to, but there hasn't been a solution presented thus far that is an actual fix for the problem. Originally, I identified that if I selected "Print to Image" the entire multi-page PDF would print as expected. Although, this solution causes the multi-page PDF to print very slowly (for the reasons noted by Mike). Another reader reported that if you install FoxIT PDF Reader, multi-page PDFs print just fine. I have verified that installing FoxIT Reader DOES INDEED allow me to print multi-page PDFs to our FS-C5015N. Again, if it was purely a driver issue, why would a multi-page PDF opened with FoxIT Reader print as expected while the same PDF opened with Adobe Reader 9, not print as expected? There also were a couple other posts about using the generic Kyocera KX driver. This is not an option for us. Finally, there was a post about changing the Post Script driver setings. We do not use the Post Script driver. And just as a side note, we have tried using the Post Script driver to see if this will resolve the multi-page PDF issue, and it does not. With that said, I implore Adobe to once again acknowledge this problem and provide users with a fix. This is a very frustrating problem.
        • 39. Re: Reader 9 PDF printing problems
        i have a hp photosmart 4250 and when i try to print a pdf document from adobe reader 9 a prepare box appears and nothing happens.when i hit cancel it does not respond.does anybody know whats going on? thanks
        1 2 Previous Next
