I was getting the same error message when I was composing an expense report. I was using Paperport to gather all of my expense data. Some pages came from docs that were already PDF and some pages were from receipts I had scanned. Well, I had scanned the receipts in at 300dpi and the other content was at 600dpi. I rescanned the receipts at 600dpi so the resolution matched for all pages and viola! We're all good.
I am also having issues. It is happening when some users try to open a pdf from an FTP.
I will see what the software team says. All of the forum stuff has me so
confused. They had me do a bunch of stuff that has led nowhere.
I am having the same problem but with a twist. When I post the pdf to my website through ftp.exe - a dos based Windows app this message comes up. However, when posted through Golive, no problem. So it's fine on my PC, Fine if posted through Golive, but corrupt when using the FTP dos protocol. Very strange. So the broswer is irrelevant, and actually is part of the file itself. I could post the two files if this would help. This has not happened in the past - it's recent.
I fixed it! I don't really know if this will help the Firefox issue or not. I added the command "Binary" to my FTP script for the FTP.EXE dos batch file. So it needed to transfer in binary mode.
I was actually supporting some Parole Officers and the error message would come up when trying to print a PDF. However I found a forum that says if you disable the java scripting under Adobe Acrobat reader properties it should work. I did this by going to the Adobe prefrences and going to java scripting and unchecking the enable java scripting because by default it will be already checked after you install the lates version of adobe reader 9.3.2. After that the error message will not appear and you can print fine, hope this helps someone.
I got the same problem last week.
I have a PDF made from 16 jpg images. I used two different versions of PDF professional to create them.
If the pdf file is on a server which sends it as application/pdf instead of stream. It crashes pdf reader 9.3 most of the time. This happened on multiple servers, and with different versions of the pdf.
If I force the file to be dowloaded by adding a .htacess file on the server, it dowload correctly, and opens correctly, but then not in the plugin as was wanted by the customer.
If opened in the browser plugin, it dissplay the "Insufficient data for an image." error and dissplay part of the jpgs, or noting at all. Even managed to crash two different computers with this. Happens in both Firefox, Crome and IE. And on both Win7 and WinXp computers.
The same error occurs in Google Chrome and even in the actual reader itself when trying to open certain PDFs. Adobe is almost impossible to contact directly and there are few clues as to how to resolve this issue on their website.
Not only were there "insufficient data for an image" errors, other errors also displayed, sometimes resulting in freezing the browser and forcing a Ctrl, Alt, Del / end program procedure.
An uninstall and reinstall of Adobe 9 did not resolve the issue. After discussion with another user who did not have Adobe 9 installed, and was still using Adobe 8, it was clear that the issues surround Adobe 9. This was uninstalled and replaced with Adobe 8 and so far all documents that did not previously open now open without a problem.
While one cannot with certainty verify whether this solution works with Firefox, it is clear that Adobe 9 has a number of issues. Backward compatibility may be one of them. Documents constructed to display on older readers obviously create problems for Adobe 9. An interesting point is that even with Adobe 9 installed, by uploading the direct link to the PDF in question to Google Docs, the document displays without a problem within Google Docs itself, though a download of the same reproduces the same errors as outlines above.
So in summary, try uninstalling Adobe 9 and install Adobe 8. NB: it is advisable to close all browsers before initiating the new install to enable browser integration.
Good luck.
Hi All,
The issue seems to be related to the contents of the PDF.
If you have images in your pdf, reopen them in any image editor. Resave them as png files and the error will disapear.
I had the same issue with gif files that were all fine, but there must have been some binary read error that adobe engine couldn't render properly.
Hope it helps.
