10 Replies Latest reply on Sep 18, 2010 9:07 PM by Brad Lawryk
    wordpress plugin
    joeq Level 1
      i'm posting this here because i know a lot of you guys use wordpress... and because the wordpress support site/forum blows.
      does anyone know a plugin (or some other technique) that will automatically embed some text with a link (ie, Click here to order my book on Amazon.") into the bottom of every post?
      thanks.
        • 1. Re: wordpress plugin
          Level 7
          Have you modifed the template at all, or are you using one out of the box?
          You can easily go into the file that calls the post and add the text (or an
          include if you think you'll want to change it often) at the bottom of each
          post.
          Or you could try this plugin (which I haven't tried, so I can't vouch for it
          other than it claims to do what you want).
          Mad Dog
          > thanks.
          • 2. Re: wordpress plugin
            joeq Level 1
            i've modified the crap out of it - so i'm not sure if your first suggestion will work.... and i'm not sure what you mean by "go into the file that calls the post". what file is that?
            also, there was no link to the plugin that you allude to. what's it called?
            thanks.
            post.
            Mad Dog
            > thanks.
            • 3. Re: wordpress plugin
              Level 7
              Sorry:
              http://www.freetimefoto.com/add_post_footer_plugin_wordpress
              > called?
              > thanks.
              > box?
              > (or an include if you think you'll want to change it often) at the
              > bottom of each post.
              > for it other than it claims to do what you want).
              > Mad Dog
              >> thanks.
              • 4. Re: wordpress plugin
                Level 7
                Have you modified the index.php page? That's usually the one that has the
                info for your basic post listing (though single.php, page.php and others can
                too). If you check out where it adds the post and before the posting date,
                tag and other stuff is (postmetadata), you should be able to just put the
                line you want and it will appear on all postings.
                MD
                > called?
                > thanks.
                > box?
                > Mad Dog
                >> thanks.
                • 5. Re: wordpress plugin
                  joeq Level 1
                  worked like a charm - thanks!
                  MD
                  > called?
                  > thanks.
                  > box?
                  > Mad Dog
                  >> thanks.
                  • 6. Re: wordpress plugin
                    Level 7
                    You're welcome!
                    > the info for your basic post listing (though single.php, page.php and
                    > others can too). If you check out where it adds the post and before
                    > the posting date, tag and other stuff is (postmetadata), you should
                    > be able to just put the line you want and it will appear on all
                    > postings.
                    > MD
                    >> called?
                    >> thanks.
                    >> box?
                    >> Mad Dog
                    >>> thanks.
                    • 7. Re: wordpress plugin
                      Level 7
                      One thing.....make sure you change that in any pages that may be special,
                      like page.php, single.php, archive.php that you use in your site.
                      MD
                      > postings.
                      > MD
                      >> called?
                      >> thanks.
                      >> box?
                      >> Mad Dog
                      >>> thanks.
                      • 8. Re: wordpress plugin
                        joeq Level 1
                        noted - thanks again.
                        MD
                        > postings.
                        > MD
                        >> called?
                        >> thanks.
                        >> box?
                        >> Mad Dog
                        >>> thanks.
                        • 9. Re: wordpress plugin
                          fort worth funeral homes
                          Hi.  Does anybody know a good plugin for theming wordpress in adobe dreamweaver CS5?
                          Would be glad to know kindly post a reply here thanks.
                          • 10. Re: wordpress plugin
                            Brad Lawryk Adobe Community Professional & MVP
                            You shouldn't need a plugin for Wordpress in CS5. Its built into CS5.
                            Creating a WordPress theme with Dreamweaver – Part 1: Learning the basics | Adobe Developer Connection http://bit.ly/bIq7WD
                            But if you really want an extension (I havn't tried it so don't know how good it is or if it works in CS5)
                            Customizing WordPress themes with Dreamweaver http://bit.ly/d11rwg
                            Brad Lawryk
                            Adobe Community Professional: Dreamweaver
                            Northern British Columbia Adobe Usergroup: Manager
                            Thompson Rivers University: Dreamweaver Instructor
                            My Adobe Blog: http://blog.lawryk.com
