2 Replies Latest reply on Dec 28, 2008 6:28 PM by (babelzzzz)
    Installing Adobe Reader to other than C Drive
      I cannot seem to download Adobe Reader 9 to anything other than my C Drive. I need it to install somewhere else. How do I accomplish this?
        • 1. Re: Installing Adobe Reader to other than C Drive
          MichaelKazlow MVP & Adobe Community Professional
          Adobe apps want to be on the C drive. If you get it to reside on a
          different drive you will still find that a large chunk of code will
          still be on the C drive. If you are running out of room the c drive it
          is time to get a larger drive.
          Mike
          • 2. Re: Installing Adobe Reader to other than C Drive
            Do on command prompt a logical substitution to an existing folder on a real drive. For example:
            Subst c: f:\DiskC
            Assuming that F: is your existing system drive and "DiskC" is any existing directory. For this problem I created "diskC" directory only for that purpose.
            Once executed a C: drive will appears in windows explorer that points exactly to f:\DiskC.
            Start the install as usual. It could be longer to process but it will eventually succeed. Adobe installer don't really use the drive as no file is going to appear into f:\disqC directory. It seems this is an installer problem that query for disk C: existance. Everything is going to be installed to your system drive.
