15 Replies Latest reply on Aug 30, 2008 5:12 AM by Newsgroup_User
    Div question
    Level 7
      Is there a way to link the height of div tags to one another? I have a site
      I am working on, I have put 3 div tags in a table next to each other. In
      the first I have P7 menu, the second is the body of text to change on each
      page, and on the right a third column for additional links..
      In the first column, I have set the background image to match the image in
      the P7 menu. If I set the height to "auto", it will only be as long as the
      menu and corresponding "body" divs will be longer when the text goes past
      the height of the menu.
      If I set a fixed height, I then limit my space for text.
      So is there a way to match heights automatically of the 3 divs?
      gary
        • 1. Re: Div question
          Level 7
          One static div inside another will always cause the outer div to expand
          vertically (assuming no overflow styles).
          In this case, no. Google "faux columns" for a solution.
          Murray --- ICQ 71997575
          Adobe Community Expert
          (If you *MUST* email me, don't LAUGH when you do so!)
          http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
          http://www.dwfaq.com - DW FAQs, Tutorials & Resources
          "Gary" <garywpaul@aol.com> wrote in message
          news:g98tkm$n78$1@forums.macromedia.com...
          > site I am working on, I have put 3 div tags in a table next to each other.
          > In the first I have P7 menu, the second is the body of text to change on
          > each page, and on the right a third column for additional links..
          > the menu and corresponding "body" divs will be longer when the text goes
          > past the height of the menu.
          > Thanks
          > gary
          • 2. Re: Div question
            Level 7
            Hi Gary,
            It can be a bit tricky but you could possibly accomplish this either by
            using a repeating background image in all three <divs> or a combination
            of using the equal height script by PV11 and image backgrounds.
            http://www.projectseven.com/tutorials/css/pvii_columns/index.htm
            Why are you putting your <divs> in a table?
            have you googled 'Faux Columns'?
            > Thanks
            > gary
            • 3. Re: Div question
              Level 7
              I did just yahoo faux columns (for whatever reason google refuses to load on
              IE...but thats a question for another board), and read some things about it.
              I am putting the divs in a table because I cant seem to get them to play
              nice any other way.. if I try to put them in a wraping div, I can get two to
              sit together, but the third refuses to join.. Its an issue I want to solve
              but it is not critical for this site.
              What I will probably end up doing is setting the height to a almost
              rediculaus (oh come on...its a hard word to spell) height and fill the rest
              with graphics..
              But I still like to think of every problem as a learning expereince.
              Gary
              "Osgood" <notavailable@thisaddress.com> wrote in message
              news:g98u4e$nns$1@forums.macromedia.com...
              > Hi Gary,
              > using a repeating background image in all three <divs> or a combination of
              >> other. In the first I have P7 menu, the second is the body of text to
              >> change on each page, and on the right a third column for additional
              >> links..
              >> in the P7 menu. If I set the height to "auto", it will only be as long
              >> as the menu and corresponding "body" divs will be longer when the text
              >> goes past the height of the menu.
              >> Thanks
              >> gary
              • 4. Re: Div question
                Level 7
                I assume you are floating the divs - if you cannot get them to all stay on
                the same horizontal line, it's almost surely because their aggregate widths
                (remember the box model) is wider than their container.
                news:g98urq$oho$1@forums.macromedia.com...
                >on IE...but thats a question for another board), and read some things about
                >it.
                > to sit together, but the third refuses to join.. Its an issue I want to
                > solve but it is not critical for this site.
                > rest with graphics..
                > Gary
                >> Hi Gary,
                >>> links..
                >>> Thanks
                >>> gary
                • 5. Re: Div question
                  Level 7
                  Murray
                  That was my first thought, but I made a wrapping div to 800, the total of
                  the 3 divs was under that, I had the first div flaoting left, same with the
                  second and the third was always lower.
                  I think I told you I recently started using divs at viriginia's suggestion,
                  plus I read they load faster, so I am still very much a novice with them. I
                  also have been mitrating from design view to code view, but having grown up
                  on using design, its a slow prcess., however one I want to accomplish.
                  "Murray *ACE*" <forums@HAHAgreat-web-sights.com> wrote in message
                  news:g98vi9$p8g$1@forums.macromedia.com...
                  >>about it.
                  >> Gary
                  >>> Hi Gary,
                  >>>> links..
                  >>>> Thanks
                  >>>> gary
                  • 6. Re: Div question
                    Level 7
                    Gary wrote:
                    > Murray
                    When you say lower do you mean it is placed directly under the first
                    <div> or just not aligned to the top of the other two <divs>?
                    >>> about it.
                    >>> Gary
                    >>>> Hi Gary,
                    >>>>> links..
                    >>>>> Thanks
                    >>>>> gary
                    • 7. Re: Div question
                      Level 7
                      No, it is over to the right (float right) and down, almost (or perhaps)
                      exactly at the bottom of the middle div
                      news:g992l2$sbj$1@forums.macromedia.com...
                      > Gary wrote:
                      >> Murray
                      >> the second and the third was always lower.
                      > When you say lower do you mean it is placed directly under the first <div>
                      >> suggestion, plus I read they load faster, so I am still very much a
                      >> novice with them. I also have been mitrating from design view to code
                      >> view, but having grown up on using design, its a slow prcess., however
                      >>> on the same horizontal line, it's almost surely because their aggregate
                      >>> widths (remember the box model) is wider than their container.
                      >>>> load on IE...but thats a question for another board), and read some
                      >>>> things about it.
                      >>>> play nice any other way.. if I try to put them in a wraping div, I can
                      >>>> get two to sit together, but the third refuses to join.. Its an issue I
                      >>>> want to solve but it is not critical for this site.
                      >>>> Gary
                      >>>>> Hi Gary,
                      >>>>> by using a repeating background image in all three <divs> or a
                      >>>>> combination of using the equal height script by PV11 and image
                      >>>>> backgrounds.
                      >>>>>> a site I am working on, I have put 3 div tags in a table next to each
                      >>>>>> to change on each page, and on the right a third column for
                      >>>>>> additional links..
                      >>>>>> image in the P7 menu. If I set the height to "auto", it will only be
                      >>>>>> as long as the menu and corresponding "body" divs will be longer when
                      >>>>>> the text goes past the height of the menu.
                      >>>>>> Thanks
                      >>>>>> gary
                      • 8. Re: Div question
                        Level 7
                        How about we see your code?
                        news:g994a9$ui$1@forums.macromedia.com...
                        >> Gary wrote:
                        >>> Murray
                        >>> of the 3 divs was under that, I had the first div flaoting left, same
                        >>> with the second and the third was always lower.
                        >>>>> things about it.
                        >>>>> I want to solve but it is not critical for this site.
                        >>>>> Gary
                        >>>>>> Hi Gary,
                        >>>>>> backgrounds.
                        >>>>>>> have a site I am working on, I have put 3 div tags in a table next
                        >>>>>>> to each other. In the first I have P7 menu, the second is the body
                        >>>>>>> of text to change on each page, and on the right a third column for
                        >>>>>>> additional links..
                        >>>>>>> be as long as the menu and corresponding "body" divs will be longer
                        >>>>>>> when the text goes past the height of the menu.
                        >>>>>>> Thanks
                        >>>>>>> gary
                        • 9. Re: Div question
                          Level 7
                          Actually, the code is gone, I went the way of the div nested in a table
                          yesterday...got tired of fighting..
                          But next one I build I'll post it.
                          As always I appriciate you input.
                          gary
                          news:g994f3$164$1@forums.macromedia.com...
                          >>> Gary wrote:
                          >>>> Murray
                          >>>>> stay on the same horizontal line, it's almost surely because their
                          >>>>> aggregate widths (remember the box model) is wider than their
                          >>>>> container.
                          >>>>>> things about it.
                          >>>>>> can get two to sit together, but the third refuses to join.. Its an
                          >>>>>> issue I want to solve but it is not critical for this site.
                          >>>>>> the rest with graphics..
                          >>>>>> Gary
                          >>>>>>> Hi Gary,
                          >>>>>>> backgrounds.
                          >>>>>>>> body of text to change on each page, and on the right a third
                          >>>>>>>> Thanks
                          >>>>>>>> gary
                          • 10. Re: Div question
                            Level 7
                            Sounds like you to need read up on clearing floats. Once you have got
                            your head around them you will be on the road to success.
                            Steve
                            • 11. Re: Div question
                              Level 7
                              Good luck! Let's see this Frankenstein you have created! 8)
                              news:g9956m$1tp$1@forums.macromedia.com...
                              > gary
                              >>>> Gary wrote:
                              >>>>> Murray
                              >>>>>> container.
                              >>>>>>> things about it.
                              >>>>>>> Gary
                              >>>>>>>> Hi Gary,
                              >>>>>>>> either by using a repeating background image in all three <divs> or
                              >>>>>>>> a combination of using the equal height script by PV11 and image
                              >>>>>>>> backgrounds.
                              >>>>>>>>> longer when the text goes past the height of the menu.
                              >>>>>>>>> Thanks
                              >>>>>>>>> gary
                              • 12. Re: Div question
                                Level 7
                                Well when the next lightning storm comes by and I plug it in, I'll drop you
                                a note..
                                news:g995n8$2g3$1@forums.macromedia.com...
                                >> gary
                                >>>>> Gary wrote:
                                >>>>>> Murray
                                >>>>>> total of the 3 divs was under that, I had the first div flaoting
                                >>>>>> left, same with the second and the third was always lower.
                                >>>>>> code view, but having grown up on using design, its a slow prcess.,
                                >>>>>>> container.
                                >>>>>>>> to load on IE...but thats a question for another board), and read
                                >>>>>>>> expereince.
                                >>>>>>>> Gary
                                >>>>>>>>> Hi Gary,
                                >>>>>>>>> or a combination of using the equal height script by PV11 and
                                >>>>>>>>> image backgrounds.
                                >>>>>>>>>> next to each other. In the first I have P7 menu, the second is
                                >>>>>>>>>> the body of text to change on each page, and on the right a third
                                >>>>>>>>>> only be as long as the menu and corresponding "body" divs will be
                                >>>>>>>>>> Thanks
                                >>>>>>>>>> gary
                                • 13. Re: Div question
                                  Level 7
                                  And it was like that in all browsers or only in IE?
                                  Because if it is the latter it could have been a simple margin issue
                                  (sometimes IE doubles margin on floats) or due to the content of the DIVs.
                                  Next time you give this DIV layout a shot, make sure to use
                                  "display:inline;" on DIVs that are floated *and* have a margin too (both in
                                  the same direction).
                                  If this still doesn't fix your problem, use "overflow:hidden;" on the DIVs
                                  to find out if the problem does not come from a nested element.
                                  Thierry
                                  Articles and Tutorials: http://www.TJKDesign.com/go/?0
                                  http://developer.yahoo.com/ helps you build applications and mashups
                                  • 14. Re: Div question
                                    Level 7
                                    Actually It never made it to a browser, it was in design view that it would
                                    not work, so I scrapped it. Now I may have previewed it, not sure I dont
                                    recall, but it makes me nervous to base a design that looks out of whack in
                                    design veiw.
                                    But next time I will watch out for your point...
                                    Thanks much
                                    Gary
                                    "Thierry" <thierry@invalid.com> wrote in message
                                    news:g9ag23$fnc$1@forums.macromedia.com...
                                    > in the same direction).
                                    > Thierry
                                    • 15. Re: Div question
                                      Level 7
                                      > would not work, so I scrapped it. Now I may have previewed it, not sure I
                                      > dont recall, but it makes me nervous to base a design that looks out of
                                      > whack in design veiw.
                                      Preview before making this decision. Even CS4's Design view is not perfect,
                                      and CS3's is not as good as CS4.
                                      "GPaul" <gwpaul@ptd.net> wrote in message
                                      news:g9basi$dug$1@forums.macromedia.com...
                                      > Thanks much
                                      > Gary
                                      >> DIVs.
                                      >> DIVs to find out if the problem does not come from a nested element.
                                      >> Thierry
