1 Reply Latest reply on Oct 4, 2006 6:17 AM by Newsgroup_User
    Keeping your tab place - cfform
    Level 7
      Is there a way to maintain the tab you are on after submitting a form that
      returns to the same page and after the form reloads?
        • 1. Re: Keeping your tab place - cfform
          Level 7
          one way could be to pass the tab state in a hidden form field:
          you would need to set a variable to the current tab state
          <cfset tabname = "thetabid">
          then add a hidden field to your form
          <form>
          <input type="hidden" name="tabtoload"
          value="<cfoutput>#tabname#</cfoutput>">
          </form>
          then towards the top of the page, when it it reloaded, check to see that
          a value is passed, and if so call the right tab. note, not sure how
          you're doing the tabs so alter that part....
          <cfparam name="form.tabtoload" default="">
          <cfif LEN(form.tabtoload) GT 0>
          <!--- call tab --->
          <!--- insert appropriate code here.... --->
          <cfoutput>#form.tabtoload#</cfoutput>
          <cfif>
          hope that helps. im sure there are other ways to do it too.....
