4 Replies Latest reply on Feb 26, 2009 1:30 PM by (sbob)
    input user password with AR?
    (Stefan_Kärst)
      I've read http://www.adobe.com/products/acrobat/acrrfaq.html and other sources regarding commenting PDFs with the Acrobat Reader.
      There are tools out there to encrypt a pdf-file and set a user password. If I do this the document security shows, that it is possible to add comments to the document (with the user password).
      But how do I enter the user password with AR? If a master password is set, a popup windows appears after opening the document, but what is the user password good for?
      There is a plugin in my AR9.0 which is for commenting PDFs.
      greetings from germany
      Stefan K.
        • 1. Re: input user password with AR?
          Bernd Alheit Adobe Community Professional & MVP
          There are a permission password and a open password. Owners of the permission password can change the security settings. Owners of the open password can open the PDF document.
          • 2. Re: input user password with AR?
            (Stefan_Kärst) Level 1
            thanks Bernd,
            "There are a permission password and a open password."
            ok
            "Owners of the open password can open the PDF document."
            ok
            "Owners of the permission password can change the security settings."
            ok, but
            - changing the permissions requires Adobe Acrobat, right? not the AReader?
            - why are the document properties different in the document properties screen in AR?
            see: http://users.minet.uni-jena.de/~zsk/pdfs/StundenplanAR813.png
            this suggests that the permission password (user password?) is for protecting the document properties, which are listet there - not - for protecting the change of the security settings.
            - why are the document properties(*) different when opening the same document via Adobe Acrobat?
            see: http://users.minet.uni-jena.de/~zsk/pdfs/StundenplanA812std.png
            (*) this looks like the so called document properties are not properties of the document but properties of the adobe appl. I use to open it.
            this is all really confusing.
            Here is my questiong again: Is it possible to add comments to a document via AR if it has a user password? -> (why does the document security window in StundenplanAR813.png show a Commenting: Allowed?? and why does a Addon in AR exisist that is called Comments??)
            greetings
            Stefan K.
            • 3. Re: input user password with AR?
              Yes, Adobe Reader can't change permissions.
              You see different security settings in Reader and Acrobat because Acrobat can more than Reader.
              The user doesn't need a password. When the document was enabled for Commenting in Adobe Reader a user can add comments. In Adobe Acrobat Professional you can assign the usage rights to the PDF document. Use menu Comments > Enable for Commenting and Analysis in Adobe Reader...
              • 4. Re: input user password with AR?
                You can save comments and form data with Foxit (which is free and smaller than Adobe)
