0 Replies Latest reply on Mar 11, 2009 4:18 AM by (hakunamatata)
    Set default filename for file save dialog on Save button click
    Level 1
      I am using AxAcroPDF (version 9.0) control to view pdf files in windows forms (C#). The pdf loads into the viewer in the form. Now, when I click on the Save button in the viewer, a Save dialog pops up with a default filename having complete path info.
      If I have loaded the pdf file into AxAcroPDF viewer with filename:
      "C:\Documents and Settings\KB_Kravi\My Documents\CustomerList.pdf"
      then in the save dialog, the default filename will be:
      "C_Documents_and_Settings_KB_Kravi_My Documents_CustomerList.pdf"
      Is there any option to set the default filename in the save dialog to some short name, instead of this lengthy name?
      Ravi.
