0 Replies Latest reply on Mar 24, 2009 6:42 AM by (Clarence_Zeng)
    [FDF] Parameters for PDF
      I have a link that works as below
      http://host/appname/xxx.pdf#FDF=/appname/LoadSOP?doc_id=yyy.pdf&hostname=host
      Basically, the link performs the following function:
      1) Open http://host/appname/xxx.pdf
      2) Supply this PDF with the following FDF parameter:
      3) LoadSOP is a Java Servlet, that takes in the querystring doc_id=yyy.pdf&hostname=host
      4) ... and converts them to parameters stored in a FDF file.
      5) xxx.pdf will pick up the FDF File and show the parameters
      However this is not working.
      Is it because the FDF parameter needs an absolute link instead of a relative link? Thanks.
