0 Replies Latest reply on Feb 18, 2008 3:03 PM by (Ray_Kareer)
    Adobe Reader 8 memory leak
      There seems to be a private byte memory leak with Adobe Reader 8.0.0 and 8.1.2 (tested both) when you try to print a PDF document. If you monitor the private bytes usage of the AcroRD32.exe with perfmon and then try to print you will see the memory usage jump and it does not come back down after the print job. In fact, it keeps on rising as you keep on sending a new print job. The only way to release the memory is to close the document and reopen it.
