0 Replies Latest reply on Mar 12, 2008 3:43 AM by (charlesvc)
    openoffice api converted pdf not loading using acrobat viewer
      While i used AcrobatFaxProducer of RFAX component java api which in turn uses Acrobat.jar and MRJToolkit to support pdf documents to fax.
      but you know while I tried to fax a pdf document which is being converted from word file using openoffice api, I got an error as follows:--
      Kindly requested to revert back with a solution for this.
      com.adobe.acrobat.sidecar.FontException:Corrupted or unrecognized font ().
      at com.adobe.acrobat.sidecar.AWTOutlines.doAWTOutlines(AWTOutlines.java:
      at com.adobe.acrobat.sidecar.AWTOutlines.<init>(AWTOutlines.java:351)
      at com.adobe.acrobat.pdf.PDFFont.<init>(PDFFont.java:1490)
      at com.adobe.acrobat.pdf.VPDFFontInstance.computePDFFont(VPDFFont.java:3
      at com.adobe.acrobat.pdf.VPDFFont.computeObject(VPDFFont.java:146)
      at com.adobe.pe.notify.VValuePurgeable.compute(VValuePurgeable.java:76)
      at com.adobe.pe.notify.VValue.handleRequest(VValue.java:172)
      at com.adobe.pe.notify.VValuePurgeable.objectValue(VValuePurgeable.java:
      at com.adobe.acrobat.pdf.VPDFFont.pdfFontValue(VPDFFont.java:128)
      at com.adobe.acrobat.pdf.VPDFFontByRef.computePDFFont(VPDFFont.java:260)
      at com.adobe.acrobat.pdf.VPDFFontByName.computePDFFont(VPDFFont.java:215
      at com.adobe.acrobat.pdf.Funct_cTJ.computeOffsetsAndString(TextExecuter.
      9)
      at com.adobe.acrobat.pdf.Funct_cTJ.setUp(TextExecuter.java:973)
      at com.adobe.acrobat.page.ContentParser.executeLiteral(ContentParser.jav
      at com.adobe.acrobat.page.ContentParser.churn(ContentParser.java:101)
      at com.adobe.acrobat.page.ContentArray.doSomeComputing(ContentArray.java
      at com.adobe.acrobat.page.ContentArray.thereIsContentAt(ContentArray.jav
      at com.adobe.acrobat.page.ContentArray.draw(ContentArray.java:239)
      at com.adobe.acrobat.page.ContentArray$1.draw(ContentArray.java:63)
      at com.adobe.acrobat.PDFDocument.drawPage(PDFDocument.java:191)
      at com.java4less.rfax.AcrobatFaxProducer.createImage(AcrobatFaxProducer.
      4)
      at com.java4less.rfax.AcrobatFaxProducer.getFaxPage(AcrobatFaxProducer.j
      at com.java4less.rfax.FaxModem.createFaxFiles(FaxModem.java:422)
      at com.java4less.rfax.FaxModem.open(FaxModem.java:489)
      at AcrobatFax.main(AcrobatFax.java:63)
