4 Replies Latest reply on Jun 2, 2008 8:10 AM by (toddsavage100)
    Adobe reader opening all Exe Files.
      I believe I accidently set preferences so that all exe files are opened by adobe reader. Once I uninstalled Adobe reader all .exe files went back to normal. However on re installing Adobe reader all exe files have gone back to opening using adobe reader. When Reader was uninstalled I checked the registry for exe files and was told HKEY_CLASSES_ROOT\.exe
      should have a default value of exefile, which it does and then checked HKEY_CLASSES_ROOT\exefile\shell\open\command which must have a default value of "%1" %* which it does. I can not change the registry while adobe reader is installed as the program regedit is an exe. Is there an Adobe register which I must change or another method I can use?
      Thanks if you understood that.
