3 Replies Latest reply on Sep 11, 2008 12:42 AM by (Rob_Matthews)
    Find or Search Problem
      I've tried to use the Find & Search tools on both Adobe Reader 8 and 9 to find words and selected text in a downloaded pdf document. It has failed to find words I know exist in the document; always returning zero find.
      Checking the original document properties I find the PDF Producer is 'Acrobat Distiller 6.0 (Windows), and the PDF Version is 1.4 (Acrobat 5.x)(If that makes sense to anyone)
      Any solutions anyone please?
      Rob
        • 1. Re: Find or Search Problem
          Ildhund Level 3
          Copy a bit of the text containing a search term that Find ought to
          find, and paste it into Notepad. You may find that there are spaces
          between the letters or other anomalies, in which case it's the fault
          of who (or what) -ever is producing the PDF.
          Noel
          • 2. Re: Find or Search Problem
            ~graffiti Adobe Community Professional & MVP
            >You may find that there are spaces between the letters or other anomalies
            You also may find that you can't select any text with the selection tool which would tell you that the PDF is a scan and there is no live text to search for.
            • 3. Re: Find or Search Problem
              Level 1
              OK Guys, you seem to have cracked it and I guess it is a scan even though it appears to be a pdf. document i.e. it opens with Adobe and the file saves with a pdf. icon. Copying into Notepad or trying to copy or use the selection tool results in a series of transparent boxes.
              Isn't life just too hard on times!!
              Thanks and regards,
              Rob
