• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Help: problem with OS/2 table
New Here ,
Mar 02, 2004 Mar 02, 2004
I try programmicaly read OS/2 table.
First part of table I read without problems, but with the second there are some problems. For example, I want obtain fsSelection value, and for any font this value equal 32(bold). When I obtain macStyle from HEAD table, all right. But values of macStyle and fsSelection must be identical! In what there can be a problem?
TOPICS
Open Type FDK
Views
767
Translate
Translate
Report
Report
Community guidelines
community guidelines
New Here ,
It's a little hard to tell without seeing your code but I would guess that you should double-check your code that reads in the panose and vendor values. Since they are arrays, multiple bytes need to be read before reaching the fsSelection value.
Votes
Translate
Translate
Report
Report
New Here ,
Mar 03, 2004 Mar 03, 2004
LATEST
My Code:
But in panose and vendor information is right. And method of working with tables is the same. But problems only with this table, and I don't know why :(
typedef struct _tagTT_OFFSET_TABLE{
USHORT uMajorVersion;
USHORT uMinorVersion;
USHORT uNumOfTables;
USHORT uSearchRange;
USHORT uEntrySelector;
USHORT uRangeShift;
}TT_OFFSET_TABLE;
typedef struct _tagTT_TABLE_DIRECTORY{
char szTag[4]; //table name
ULONG uCheckSum; //Check sum
ULONG uOffset; //Offset from beginning of file
ULONG uLength; //length of the table in bytes
}TT_TABLE_DIRECTORY;
typedef struct _tagTT_OS_RECORD{
USHORT version;
SHORT xAvgCharWidth;
USHORT usWeightClass;
USHORT usWidthClass;
SHORT fsType;
SHORT ySubscriptXSize;
SHORT ySubscriptYSize;
SHORT ySubscriptXOffset;
SHORT ySubscriptYOffset;
SHORT ySuperscriptXSize;
SHORT ySuperscriptYSize;
SHORT ySuperscriptXOffset;
SHORT ySuperscriptYOffset;
SHORT yStrikeoutSize;
SHORT yStrikeoutPosition;
SHORT sFamilyClass;
PANOSE panose;
ULONG ulUnicodeRange1;
ULONG ulUnicodeRange2;
ULONG ulUnicodeRange3;
ULONG ulUnicodeRange4;
CHAR achVendID[4];
USHORT fsSelection;
USHORT usFirstCharIndex;
USHORT usLastCharIndex;
USHORT sTypoAscender;
USHORT sTypoDescender;
USHORT sTypoLineGap;
USHORT usWinAscent;
USHORT usWinDescent;
ULONG ulCodePageRange[2];
}TT_OS_RECORD;
// structure for writing results
typedef struct _tagFONT_PROPERTIES{
CString csName;
USHORT Weight;
USHORT Width;
BOOL bItalic;
BOOL bUnderline;
BOOL bStrikeOut;
USHORT uFamily;
}FONT_PROPERTIES, *LPFONT_PROPERTIES;
// from Big Endian to Little Endian
#define SWAPWORD(x) MAKEWORD(HIBYTE(x), LOBYTE(x))
#define SWAPLONG(x) MAKELONG(SWAPWORD(HIWORD(x)), SWAPWORD(LOWORD(x)))
LPFONT_PROPERTIES lpFontProps = new FONT_PROPERTIES;
CString pstrName = "C:\\WINDOWS\\Fonts\\ANTQUABI.TTF";
lpFontProps->csName = "";
GetFontPropertiesFromOS(pstrName, lpFontProps);
BOOL CMyDlg::GetFontPropertiesFromOS(LPCTSTR lpszFilePath, LPFONT_PROPERTIES lpFontProps)
CFile f;
BOOL bRetVal = FALSE;
if(f.Open(lpszFilePath, CFile::modeRead|CFile::shareDenyWrite)){
TT_OFFSET_TABLE ttOffsetTable;
f.Read(&ttOffsetTable, sizeof(TT_OFFSET_TABLE));
ttOffsetTable.uNumOfTables = SWAPWORD(ttOffsetTable.uNumOfTables);
ttOffsetTable.uMajorVersion = SWAPWORD(ttOffsetTable.uMajorVersion);
ttOffsetTable.uMinorVersion = SWAPWORD(ttOffsetTable.uMinorVersion);
//check is this is a true type font and the version is 1.0
if(ttOffsetTable.uMajorVersion != 1 || ttOffsetTable.uMinorVersion != 0)
return bRetVal;
TT_TABLE_DIRECTORY tblDir;
BOOL bFoundOS = FALSE;
CString csTemp;
for(int i=0; i< ttOffsetTable.uNumOfTables; i++){
f.Read(&tblDir, sizeof(TT_TABLE_DIRECTORY));
strncpy(csTemp.GetBuffer(5), tblDir.szTag, 4);
csTemp.ReleaseBuffer(4);
if(csTemp.CompareNoCase(_T("OS/2")) == 0){
bFoundOS = TRUE;
tblDir.uLength = SWAPLONG(tblDir.uLength);
tblDir.uOffset = SWAPLONG(tblDir.uOffset);
break;
else if(csTemp.IsEmpty())
break;
if(bFoundOS)
int nPos = f.GetPosition();
f.Seek(tblDir.uOffset, CFile::begin);
TT_OS_RECORD ttOSRecord;
bFoundOS = FALSE;
if(lpFontProps->csName.IsEmpty())
f.Read(&ttOSRecord, sizeof(TT_OS_RECORD));
ttOSRecord.version = SWAPWORD(ttOSRecord.version);
lpFontProps->Weight = SWAPWORD(ttOSRecord.usWeightClass);
lpFontProps->Width = SWAPWORD(ttOSRecord.usWidthClass);
ttOSRecord.sFamilyClass = SWAPWORD(ttOSRecord.sFamilyClass);
// high byte of this field contains the family class
BYTE hb = HIBYTE(ttOSRecord.sFamilyClass);
// low byte contains the family subclass
BYTE lb = LOBYTE(ttOSRecord.sFamilyClass);
ttOSRecord.fsSelection = SWAPWORD(ttOSRecord.fsSelection); // this is always 32
lpFontProps->uFamily = ttOSRecord.panose.bFamilyType;
ttOSRecord.usFirstCharIndex = SWAPWORD(ttOSRecord.usFirstCharIndex);
bRetVal = TRUE;
f.Close();
return bRetVal;
Votes
Translate
Translate
Report
Report
