6 Replies Latest reply on Sep 2, 2008 5:24 AM by Newsgroup_User
    ASP and Adobe Director 11
    Level 7
      Hi again.
      Does anybody knows if it is possible to call an ASP page from a Director
      movie and set the results into the .dcr?
      It would be samething similar to the LoadVariables in ActionScript.
      I'm getting problems with remote access to the data base and I think this
      could be a solution.
      Thank you and regards.
        • 1. Re: ASP and Adobe Director 11
          Level 7
          Read the docs for getNetText() and/or postNetText(). Also
          < http://www.shocknet.org.uk/index.asp>
          • 2. Re: ASP and Adobe Director 11
            Level 7
            Thank you for your answer Sean
            It's a good reference page, but I'm still having problems and I can't find a
            solution.
            I use the following to connect with an ASP page:
            infoList = ["pregunta_numero":pregunta_numero,
            "pregunta_concello":pregunta_concello]
            netID = postNetText(" http://www.mydomainname.es/myaspfile.asp",infoList)
            The ASP file works perfectly if I call it from the URL and I asign directly
            the values. It returns a string like this:
            #preguntaweb:¿This is the question?#respuesta1:first
            answer#respuesta2:second answer#respuesta3:third answer
            But I have two problems.
            In first place, I can't obtain anything from my postNetText.
            When I use:
            aString = netTextResult(netID)
            I get aString = "" and netDone(netID)=0
            That means that the "myaspfile.asp" has not being executed
            The second problem is what to do with the returned result from the ASP? (in
            case I solve the first problem, of course ;-)
            How can I put each value in his variable?
            This is really simple in Flash but I've never done it in Director and I
            don't find any information about this.
            Thanks again.
            "Sean Wilson" <webforumsuser@macromedia.com> escribió en el mensaje de
            noticias news:g99kvf$i7i$1@forums.macromedia.com...
            • 3. Re: ASP and Adobe Director 11
              Level 7
              No it doesn't. It means the postNetText() call hasn't finished yet. Both
              it and the GET equivalent are asynchronous operations, meaning you have
              to wait (by looping on a frame, using a timeout object or the actorList)
              for it to finish before accessing any results.
              • 4. Re: ASP and Adobe Director 11
                Level 7
                Well, we've gotten it!!!
                The problem was not to wait but the way of waiting.
                I had made a loop like this:
                repeat while netDone(netID)=0 then
                nothing
                end repeat
                but I only obtained an infinite loop. My workmate solved it by using a
                simple: _movie.go(_movie.frame)
                Thank you very much Sean.
                Regards from Spain.
                noticias news:g9eu5n$8rt$1@forums.macromedia.com...
                > it and the GET equivalent are asynchronous operations, meaning you have to
                > wait (by looping on a frame, using a timeout object or the actorList) for
                • 5. Re: ASP and Adobe Director 11
                  Level 7
                  It is not good practice to lock your movie in a repeat. No other scripts
                  can execute while this loop is executing. You are better off checking
                  the status of netDone in an exitFrame handler or using a timer object.
                  > nothing
                  > end repeat
                  > Regards from Spain.
                  >> Both it and the GET equivalent are asynchronous operations, meaning
                  >> you have to wait (by looping on a frame, using a timeout object or the
                  >> actorList) for it to finish before accessing any results.
                  • 6. Re: ASP and Adobe Director 11
                    Level 7
                    I've really learned the lesson Dave.
                    Thank you very much.
                    Un saludo.
                    "Dave C" <no@no.com> escribió en el mensaje de noticias
                    news:g9h4f8$klv$1@forums.macromedia.com...
                    > can execute while this loop is executing. You are better off checking the
                    >> nothing
                    >> end repeat
                    >> Regards from Spain.
