3 Replies Latest reply on Mar 25, 2003 9:10 AM by (Read_Roberts)
    line break in description tables
    Level 1
      Hallo,
      how can I include a larger text into a font file structured with line
      breaks?
      e.g.
      nameid 10 "TEXT01 line break TEXT02";
      nameid 10 1 "TEXT01 line break TEXT02";
      Andreas
        • 1. Re: line break in description tables
          Level 1
          Hiya,
          I suppose using \000a\000d for windows and \0a for mac should work.
          t
          • 2. Re: line break in description tables
            Level 1
            Txortx wrote:
            > Hiya,
            > t
            Hiya too Txortx,
            This does not work! MAKEOTF don`t wont such strings in this table.
            Andreas
            BTW. If you want include an larger text file, this methode is extremly
            unusable.
            • 3. Re: line break in description tables
              Level 1
              Txortx is correct that you are supposed to be able to use strings like this. Consider the feature file name table strings:
              nameid 0 "Copyright \00a9 ...";
              nameid 0 1 "Copyright \a9 1986,..."
              Are you using the right format for the right platform? Remember, as Txortx noted, the Windows platform strings are Unicode values, and special characters need to be specifed as a 4 digit hex number, e.g "\00a9". The Mac platform strings are single-byte Mac encoded ( according to the language specified - Mac Roman is the default) , and special characters need to be specified as a two-digit hex number, e.g "\a9". We use such characters specofocations a lot, although I havem't ever tried putting in a new-line. Also, I thinl that the feature file parser is very narrow-minded, and doesn't take uppercase hex digits.
