• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
no space left in End User subarea
New Here ,
Aug 22, 2003 Aug 22, 2003
Hello FDK Developers,<br /><br />After compiling some fonts I got an error code don`t know to handle<br />right. Some glyphs don`t be encoded in unicode.<br /><br />If I change the GlyphOrderAndAliasDB and assign the glyphs direct to a<br />specific unicode value everything works well. But it should work without<br />such a workflow.<br /><br />MakeOTF reports error codes like this one:<br /><br />makeotflib [WARNING] <FontName> glyph <yen.titling> not encoded in<br />Unicode cmap: no space left in End User subarea<br /><br /><br />Andreas
TOPICS
Open Type FDK
Views
580
Translate
Translate
Report
Report
Community guidelines
community guidelines
Explorer ,
Aug 25, 2003 Aug 25, 2003
There is not much I can do about this issue. <br /> <br />The problem is that the end user block is of limited size, and your font has filled it up. MakeOTF uses this area to assign arbitrary Unicode values to all the glyphs for which its heuristics cannot derive a valid Unicode value. When this happens, there are no other Unicode values that can be used. <br /> <br />Your comment about using GAODB to assign Unicode values suggests to me that you do have valid Unicode values in mind for at least some of these glyphs; if this is the case, then you should not be letting MakeOTF assign end-user-area values, which have no semantic value and which will map to different glyphs in different fonts. The MakeOTF heuristics only cover a relatively small number of glyph names, so all glyph names not covered by the heuristics should be assigned Unicode values either by using a "uni<XXXX> name or with the third column of the GAODB file.
Votes
Translate
Translate
Report
Report
New Here ,
LATEST
Thank you Robert for your comment.
The truth is, it is enough space left in the PUA. MakeOTF stops on
position uniE13C its encoding of the rest of the glyph data.
If I set up / assign my own PUA values to the glyphs everything works
fine. BTW. This is my default workflow.
Andreas
Votes
Translate
Translate
Report
Report
