4 Replies Latest reply on Apr 20, 2004 8:33 AM by (Read_Roberts)
    H E L P mac math foonths to windows-compatible fonts
      im a novice when it comes to font development. i want to convert mac math fonts to pc-compatible fonts. ive been trying to follow the guidelines on how to do it but i cant seem to have an output. dont know how python works and i dont know if my files are correct. i have "PalatBol, PalatBolIta, Palatino, PalatIta and PalatRom" and some other mac math fonts. so how do i put it in features file, etc. and what is "an outline font" mentioned in the overview? i dont see also the window wen i double-click on the makeotf.py (regarding makeotf.py, mentioned and shown on page 2 of the documentation).
      pls help me as i have a deadline to meet.
      im pc-based by the way. thank you very much.
        • 1. Re: H E L P mac math foonths to windows-compatible fonts
          Level 1
          Addendum:
          error: could not find makeotflib or makeotflibDB
          pls help
          • 2. Re: H E L P mac math foonths to windows-compatible fonts
            Level 1
            If you simply want to convert existing fonts to an equivalent pc version, then the FDK is the wrong tool. OpenType fonts have a lot of new meta-data that older formats do not have, and you will have to spend quite a bit time researching and making choices about how to build the new data. These areas are:
            - extended set of menu names and other text info
            - Unicode encoding tables
            - OpenType layout features: these are very complex for math
            - Panose number and other data for the OS/2 table
            You best choice for the specific task of converting is the TypeTool products from FontLab ( see http://www.fontlab.com/html/typetool.html).
            You may alo be able to make do with the free conversion tools at:
            http://fondu.sourceforge.net/
            These do not cover all the flavors of font data you might want, but if you can figure out how to use them and they cover the cases of interest to you, they will be sufficient.
            I recommend the TypeTool , as it comes with a manual and requires relatively little computer and font expertise.
            The specific problem you have with the FDK shows that the Python interpreter does not know where to find the FDK add-on modules. This means in turn that you need to run the FinishInstall.py. NOTE! You have to run this as described in the installation instructions: you must run it by dragging it onto the icon for the Python interpreter. If you run it by double-clicking on it, it will make incorrect file-paths.
            • 3. Re: H E L P mac math foonths to windows-compatible fonts
              Hi, I'm a novice too.
              Hopefully seeking help regarding what simple applications are around to convert a PC font to Mac font and back again.
              Any tips on how to do the conversion would be gratefully appreciated.
              I'm using InDesign.
              I hope there is a kind helpful and knowledgable person out there.
              Many thanks. Lindsay
              What happens next?
              • 4. Re: H E L P mac math foonths to windows-compatible fonts
                Level 1
