1 Reply Latest reply on Nov 6, 2008 1:04 PM by (Francois_Driessen)
    DVCProHD Gamma Shift in AE
      I recently rendered a DVCProHD file out of Final Cut and opened the same file in After Effects CS3. For some strange reason, the footage is brighter than the original.
      I've tried changing the project settings like Blend Colors and Match Legacy but nothing works, the footage looks like someone cranked up the brightness settings.
      How do I get the footage to match 100% with the Final Cut Pro original?
        • 1. Re: DVCProHD Gamma Shift in AE
          Level 1
          Having the same issue.
          Had this in the past before CS3. Used to have to do a curves adjustment on everything that went back out to FCP - but that's no good to get colors perfectly maintained. But as far as I remembered this fixed with CS3. However. All of a sudden I'm somehow stuck the same way it used to be in the past now...
          Did you get this fixed?
          -F
